Home > General (L405) > Knocking Update
Page 3 of 5 <12345>
crookedm
2007 Range Rover Vogue SE TDV8 Java Black
I'd tell them to shove their car!
7th warranty visit!!! WTF! Wont be buying British for a long time!!
Post #274264 4th Aug 2014 4:51pm
chris_j_g
I heard from my dealer yesterday that there is now a TSB released for the knocking issue, it does include replacing this valve that appears to fix the problem, there is a lead time on the delivery of part but lets hope this finally resolves it.
Post #275724 14th Aug 2014 7:39am
Doodle
Mine's been done, but need to do some reasonable mileage before passing judgement on the success.
Will post in due course. Waited about six weeks for valve + 3 days to fit.
From those who have already posted after this fix, it should be the solution.
Happy days ahead hopefully. Rolling Eyes
Post #275727 14th Aug 2014 8:45am
CharlesA22
Scotland 2019 Range Rover Autobiography 5.0 SC V8 Baltic Blue
Latest replacement suspension components
Vehicle back in to dealer with advice that they check for latest TSB on this issue. However, JLR has only authorised them to replace the "front stabiliser bar". No other components. Unlike the bush replacements on 01/08/2014 which made no improvement whatsoever, this component replacement has improved the ride but after only 100 miles or so I am concerned that the low speed "rumble" over rough surfaces may be returning. I will persevere for some longer journeys over more varied terrain and report further. FFRR user since 1974. RR No. 10 (2021MY P525 AB delivered Nov 2020) Gone. No 11. P550e AB MY2024 delivered June 2024
Post #277538 26th Aug 2014 2:21pm
Doodle
New valve block fitted and system re-programmed one month ago and so far seems fine. Just the very odd faint knock on rough surface. So now much better to drive and live with.
Wish it had been ok from day one, as first six months of ownership had not been good.
Just a couple of other niggles to resolve and I might start to feel it's been worthwhile.
Very grateful for the support received from my dealer, which has been excellent.
All others have already posted, this is 'the fix' that works. Razz
Post #279401 6th Sep 2014 11:04am
CaptainG
United Kingdom 2013 Range Rover Autobiography SDV8 Luxor
Mine is in today so hoping they will replace this valve as its had every other mod, I did say I dont want it back unless they do. Have been told it will take 3 days to sort it, I await the possibility of a quiet ride...
Post #279710 8th Sep 2014 10:46am
modbarra
Scotland 2019 Range Rover Autobiography 5.0 V8 Loire Blue
Thumbs Up hope goes well. but three days? Shocked mine in/out same day! inc full valet..
Post #279738 8th Sep 2014 3:13pm
CaptainG
I was surprised it was 3 days, apparently first day was for other checks before LR would release part,
anyway have now picked it up and the car is transformed, so nice to drive without that noise ~ lets hope it lasts as I am now very happy, pity it took nearly 10 months before getting sorted but they got there in the end...
Post #280392 11th Sep 2014 2:42pm
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
Just had my SDV8 in for the knocking again the bulletin this time was to replace the steering rack bolts and control arm bushes. This has made a bit of improvement in steering feel but knock is still there.
Was Told by dealer next step is replace all four suspension struts JLR have this is the third step in the upgrade process so this means another trip back to dealers as they are not allowed by JLR to do all the mods in one visit.
Great customer servise just keep messing the buyers of their products around and maybe they will get bored of chasing a fix and go away.
Post #323846 23rd Apr 2015 6:08am
5.0
Unless they replace the Valve block with one with dampers the rest of what they are doing is likely to be a waste of time. Mine has been fine ever since I had this done.
Post #323927 23rd Apr 2015 11:52am
jettec
Well the knock is still there! The dealer is now replacing the whole steering rack. I did mention your advise on ARC Valve!
Will let you know how this turns out. They have given me this time a Discovery four as loaner This is a very nice car to drive.
Post #325638 3rd May 2015 2:22am
Doodle
5.0 is right.
Sounds like ARC Bar.
Mine was done last year. Still get faint knock on some surfaces however. It also leaked fluid. Complete drain after three months. Happened in seconds. That said, very much improved.
I am surprised that there is no reference to Bulletin by dealer.
Anyway, my understanding is that LR will not reimburse dealer if replaced parts are later found to be ok.
Someone on this site will have the details. Tried LR Customer Relations?
Seems a lot of work, but it may be something other than ARC.
Please keep us informed.
Post #325765 3rd May 2015 4:34pm
DangerMouseUK
United Kingdom 2017 Range Rover Autobiography SDV8 Farallon Black
If I get the knock only going over bumps and holes in the road, is that still the issue being discussed here ?
Or are your cars just knocking over smooth roads ?
Mine's a Sep 14 car, would it have been fixed by then ?
Post #325871 3rd May 2015 9:57pm
Doodle
If it's the SDV6 it's ok as it does not have this roll control system.
However, it seems some SDV8's continued through production with the old style ARC block.
Pot holes make the 'knocking' more obvious, but it can also happen on relatively reasonable surfaces.
Try going down an un-surfaced track and listen/feel the topic.
Mine was Jan 2014 build, but 6 months on for yours does not rule anything out.
Post #325911 4th May 2015 9:45am
jettec
Danger mouse the knock is on rough surfaces or pot holes or sharp bumps in the road. I have just got the car back with the replacement steering rack plus the ARC was replaced earlier .
I will let you know how this goes after I drive the car for a bit. Fingures crossed!
Post #326043 5th May 2015 7:21am
Page 3 of 5 <12345>
