Home > General (L405) > Knocking Update
Page 1 of 5 12345>
Knocking Update
At last there is apparently a new ARC valve block available so mine is going in for a second time to replace the valve block, ARC bar, link rods and air springs. Shocked
I hope this is the answer this time Big Cry
Post #263183 4th Jun 2014 1:33pm
hope this sorts it Neil.. Thumbs Up ... - .- -.
Post #263185 4th Jun 2014 1:50pm
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
Will this incur a recall for all l405 cars with active suspension or is it just a certain percentage affected? Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #263238 4th Jun 2014 6:28pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Hope it's the end of it for you.
Extremely frustrating after spending some serious money. Thumbs Up
Post #263240 4th Jun 2014 6:37pm
PaulB
Imagine having to change all of the above on every 405 that has left the factory!!
Post #263242 4th Jun 2014 6:39pm
Prop
It will be interesting to see how this pans out.
Post #263244 4th Jun 2014 6:43pm
crookedm
2007 Range Rover Vogue SE TDV8 Java Black
Or pussy out like most companies and only replace when people complain.
Post #263268 4th Jun 2014 7:45pm
CaptainG
United Kingdom 2013 Range Rover Autobiography SDV8 Luxor
Hi 5.0, just wondered if you have had this latest update fitted yet and if so how its going so far?
Post #266068 18th Jun 2014 11:48am
5.0
It is in the workshop now being done. I will post here the result when I get it back. However time will only tell if it is a permanent fix because, as others have posted, the noise comes back after a few hundred miles for any ARC bar changes which have been done previously. It remains to be seen if the new valve block is the answer to the problem.
Post #266070 18th Jun 2014 11:57am
5.0
Well it's back and the knocking has gone. Let's see if it lasts. I shall be racking up some miles on a holiday to the West Country in the next week or so. If it comes back from that silent I shall be a happy man. The combination of no knocking and no diesel makes for such a nice quiet drive compared to the loaner I have been knocking about in (pun intented) the last couple of days Laughing
The main change according to the technician that should make the difference is a reengineered valve block and software. There are also two dampers on the ARC system now to stop shocks going through the body when you hit bumps.
Post #266278 19th Jun 2014 5:43pm
RR2008HSE
Good luck! Thumbs Up
Post #266305 19th Jun 2014 8:37pm
Doodle
5.0, when you mention the information from the technician regarding the two dampers on the ARC, are these a completely new addition?
I had the ARC replaced two months ago and it's as bad as before. Knocking and I can feel every ripple on the road surface through the steering and the floor.
Really hope this is a solution rather than a patch for you and the rest of us.
If you are satisfied with this fix, I will go back to my dealer.
Enjoy the West Country and the drive. Thumbs Up
Post #266636 21st Jun 2014 10:05pm
5.0
Doodle, yes, valve block dampers and software all new.
So far so good, but only a hundred or so miles done since. The last ARC bar change lasted about 200. Rolling Eyes
Post #266753 22nd Jun 2014 6:21pm
RR-5.0SC
United Kingdom 2013 Range Rover Autobiography 5.0 SC V8 Santorini Black
hi 5.0, I also have this issue how is the latest fix holding out still no knocking Question
Post #267402 26th Jun 2014 12:29am
5.0
Nothing more to add to my previous post at the moment. I will testing it out on holiday next week and will let you know how it does. Thumbs Up
Post #267480 26th Jun 2014 4:29pm
Page 1 of 5 12345>
