Home > General (L405) > Knocking Update |
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 |
I'd tell them to shove their car!
4th Aug 2014 3:51pm |
chris_j_g Member Since: 12 Dec 2008 Location: Bristol Posts: 4 |
I heard from my dealer yesterday that there is now a TSB released for the knocking issue, it does include replacing this valve that appears to fix the problem, there is a lead time on the delivery of part but lets hope this finally resolves it. |
14th Aug 2014 6:39am |
Doodle Member Since: 02 Nov 2013 Location: Midlands Posts: 127 |
Mine's been done, but need to do some reasonable mileage before passing judgement on the success.
14th Aug 2014 7:45am |
New valve block fitted and system re-programmed one month ago and so far seems fine. Just the very odd faint knock on rough surface. So now much better to drive and live with.
6th Sep 2014 10:04am |
CaptainG Member Since: 16 Dec 2013 Location: Bristol Posts: 13 |
Mine is in today so hoping they will replace this valve as its had every other mod, I did say I dont want it back unless they do. Have been told it will take 3 days to sort it, I await the possibility of a quiet ride... |
8th Sep 2014 9:46am |
modbarra Member Since: 28 Mar 2009 Location: northampton Posts: 237 |
hope goes well. but three days? mine in/out same day! inc full valet.. |
8th Sep 2014 2:13pm |
I was surprised it was 3 days, apparently first day was for other checks before LR would release part,
11th Sep 2014 1:42pm |
jettec Member Since: 16 Jul 2013 Location: Melbourne Posts: 229 |
Just had my SDV8 in for the knocking again the bulletin this time was to replace the steering rack bolts and control arm bushes. This has made a bit of improvement in steering feel but knock is still there.
23rd Apr 2015 5:08am |
5.0 Member Since: 25 Feb 2012 Location: Surrey Posts: 718 |
Unless they replace the Valve block with one with dampers the rest of what they are doing is likely to be a waste of time. Mine has been fine ever since I had this done. |
23rd Apr 2015 10:52am |
Well the knock is still there! The dealer is now replacing the whole steering rack. I did mention your advise on ARC Valve!
3rd May 2015 1:22am |
5.0 is right.
3rd May 2015 3:34pm |
DangerMouseUK Member Since: 03 May 2015 Location: London Posts: 69 |
If I get the knock only going over bumps and holes in the road, is that still the issue being discussed here ?
3rd May 2015 8:57pm |
If it's the SDV6 it's ok as it does not have this roll control system.
4th May 2015 8:45am |
Danger mouse the knock is on rough surfaces or pot holes or sharp bumps in the road. I have just got the car back with the replacement steering rack plus the ARC was replaced earlier .
5th May 2015 6:21am |
