![]() | Home > General (L405) > Knocking Update |
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 ![]() ![]() |
I'd tell them to shove their car!
chris_j_g Member Since: 12 Dec 2008 Location: Bristol Posts: 4 ![]() ![]() ![]() |
I heard from my dealer yesterday that there is now a TSB released for the knocking issue, it does include replacing this valve that appears to fix the problem, there is a lead time on the delivery of part but lets hope this finally resolves it. |
Doodle Member Since: 02 Nov 2013 Location: Midlands Posts: 127 ![]() ![]() |
Mine's been done, but need to do some reasonable mileage before passing judgement on the success.
New valve block fitted and system re-programmed one month ago and so far seems fine. Just the very odd faint knock on rough surface. So now much better to drive and live with.
CaptainG Member Since: 16 Dec 2013 Location: Bristol Posts: 13 ![]() ![]() ![]() |
Mine is in today so hoping they will replace this valve as its had every other mod, I did say I dont want it back unless they do. Have been told it will take 3 days to sort it, I await the possibility of a quiet ride... |
modbarra Member Since: 28 Mar 2009 Location: northampton Posts: 237 ![]() ![]() ![]() |
I was surprised it was 3 days, apparently first day was for other checks before LR would release part,
jettec Member Since: 16 Jul 2013 Location: Melbourne Posts: 229 ![]() ![]() ![]() |
Just had my SDV8 in for the knocking again the bulletin this time was to replace the steering rack bolts and control arm bushes. This has made a bit of improvement in steering feel but knock is still there.
5.0 Member Since: 25 Feb 2012 Location: Surrey Posts: 718 ![]() ![]() |
Unless they replace the Valve block with one with dampers the rest of what they are doing is likely to be a waste of time. Mine has been fine ever since I had this done. |
Well the knock is still there! The dealer is now replacing the whole steering rack. I did mention your advise on ARC Valve!
5.0 is right.
DangerMouseUK Member Since: 03 May 2015 Location: London Posts: 69 ![]() ![]() ![]() |
If I get the knock only going over bumps and holes in the road, is that still the issue being discussed here ?
If it's the SDV6 it's ok as it does not have this roll control system.
Danger mouse the knock is on rough surfaces or pot holes or sharp bumps in the road. I have just got the car back with the replacement steering rack plus the ARC was replaced earlier .
