Home > Maintenance & Mods (L322) > Aero Front Windshield Wipers Fitted
Page 8 of 13 <123 ... 789 ... 111213>
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Best option craig. If we started using in clinometers and measuring to minutes and seconds its a different ball game. So I would say your option is as good as any. Thumbs Up
Post #298749 13th Dec 2014 11:33am
a great simple idea that is craig Thumbs Up
or print out on cardboard and cut it to the desired angle, next we will build a tracy island..... Mr. Green ... - .- -.
Post #298755 13th Dec 2014 11:55am
Craig
 2008 MY Supercharged
Post #298757 13th Dec 2014 11:57am
mjdronfield
Just ordered some from the link that Smutt posted. The Continental ones.
My LR ones are smearing now, right over the rain sensor, so the auto wipers pretty much stay on constantly, irrespective of the rain. Peachy......
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #299956 19th Dec 2014 11:25pm
Thumbs Up Bow down Bow down Bow down Whistle Thumbs Up
Post #299959 19th Dec 2014 11:33pm
kevieb
England 2006 Range Rover Vogue SE TDV8 Zermatt Silver
Hello everyone i am new to this site Very Happy. I have just fitted the ebay wipers from bolt on bits and they do fit but i was not impressed with the clip that holds them to the arm.If the button that locates in the wiper arm was just a bit longer i think it would make them more secure.As to noise there is none but i have not had the chance to try them in heavy rain yet. I also broke the plastic clip on the near side it just fell apart as i removed the blade.Can i buy this insert or does it come with new blades such as bosch 808? Better to remain silent and a thought a fool than to speak and remove all doubt.
Post #300231 21st Dec 2014 1:17pm
Arkle
n1cktdv8 wrote:
clunk remains Shocked
The ONLY reason I bought these was to eliminate that clunk... my genuine LR wipers are just fine, with a clunk
Thought these ones took that away. Doesn't make good reading now to find out the clunk remains and they are fiddly to fit?
Hi Nick,
Which ones clunked?
http://www.ebay.co.uk/itm/231202190017?clk...rmvSB=true
Or the ones from Advanced Factors?
http://www.advancedfactors.co.uk/bv2626s-l...6114-p.asp
TIA,
Paul.
Post #313901 20th Feb 2015 12:00pm
the AF ones are the conti jobbys Paul. ... - .- -.
Post #313905 20th Feb 2015 12:37pm
Arkle
Thanks, Stan.
I'll think I'll give the Conti's a try,
I had seen some on ebay (link below) but even though they offer to buy their customers a new Range Rover if the wipers don't fit, that doesn't necessarily mean that the wipers will actually work properly.
http://www.ebay.co.uk/itm/AERO-FLAT-Front-...5408769edf
Post #313928 20th Feb 2015 2:51pm
apologies Paul, the first batch supplied by AF were conti's but they sell a different make now.. ... - .- -.
Post #313932 20th Feb 2015 3:06pm
Arkle
No worries. I'll order the Conti's. Thumbs Up
Post #313935 20th Feb 2015 3:12pm
n1cktdv8
Well like some of the others, I jumped on a band wagon. Bought mine to eliminate a clunking noise at the top of the swipe on the drivers side. Alas it wasn't long after my purchase that ppl commented the clunk remained. Mine are wrapped still in the garage. I have cleaned the rubbers on the genuine LR's and will see how they go. I am a bit confused with how and why it's seemingly quite awkward to swap/upgrade your wiper blades?
Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #313943 20th Feb 2015 3:52pm
When are these due back in stock please?
Post #313946 20th Feb 2015 4:00pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
@ Nick, I cured a clunk in mine by removing the wiper arms and re-setting them per the diagram Stan shared. the underneath part where the cast alloy grooved part sits on the spindle is convex to allow different angles of fitting. I've also seen people twist the wiper arms to get a flatter blade which is less likely to clunk at either extreme of travel.
I couldn't believe a supposedly high end vehicle could have such a convoluted wiper arrangement.
If you want to remove the cast allow piece to allow alteration of the 'parked' position you will need a big puller, the usual 'Laser' twin arm wiper removal tools don't have enough travel to accommodate the honking great big spindle!
Hope it's of some use.
Steve
Post #313950 20th Feb 2015 4:06pm
Arkle
Continental wipers fitted and all is good so far. Zero clunk when out in drizzle a couple of days go.
I struggled with the fitting at first, but the key is that there should be no plastic at all left on the original arms.
I got a slightly tighter fit by gently squeezing the metal opening together with a pair of pliers.
Thanks for the advice. Thumbs Up
Post #317038 9th Mar 2015 1:15am
