Home > Maintenance & Mods (L322) > Aero Front Windshield Wipers Fitted
Page 11 of 13 <123 ... 10 111213>
procee
@Gyre8
Hi, I'm pretty sure these are the ones I bought. There are also DKC500080PMD and one is for LHD one for RHD but I can't see how there would be a difference personally? Anyhoo, these ones are Britpart, but seem to work fine. I have no connection with the selling company etc, it's just where I bought them from.
You can get them elsewhere, you can alos buy genuine LR ones.
Winter Wipers 2006 MY FFRR 4.2 S/C autobiography (Auckland Blue - 901)
1996 Discovery 300Tdi S (death by rusting) (Silver)
1995 Volvo 850 T-5 est (now in Valhalla) (verdigris metallic)
1987 Volvo 240 GL est (now in Valhalla - not owned but driven lots)
1990 Kawasaki ZZR600 Blue
1979 Honda CB250 NA Superdream Red
Post #500933 8th Jan 2019 4:48pm
bgennette
Australia 2003 Range Rover HSE Td6 Java Black
How-to video
Aeroblade Swap for L322, Step-by-step
Arm - Ends with a 3 sided steel box section 19mm wide by 14mm high with top cut out for last 19mm.
It has a single 8mm hole 10mm from the end. The metal is 1mm thick
Range Rover Original Equipment Parts to be removed -
Adaptor 1 - A thin steel U-bracket snaps in on the top of the arm to reduce the size of the hole to 6mm.
Adaptor 2 - A plastic U-Bracket snaps in on the top of the blade with round lugs going into the 6mm holes.
This bracket has the sliding lock button that holds the original blade assembly.
The driver's side bracket also has a wing attached.
1 - Remove the U-brackets
Take the wiper arms off the vehicle. Just one nut on each, not too tight.
Remove the wiper assemblies from the arms (move slide clip with a flat bladed screwdriver)
Pivot the blade Slide Clip brackets 90° at the end of the arms
Use a thin sharp blade to lever the U-brackets inwards, then pull/roll/tug them off of the arms.
2 - Fit the Aeroblades
Slide the new wiper assemblies onto the arms until the 8mm round lugs snap into the holes.
Replace the wiper arms onto the vehicle. See adjustment pictures in manual.
Next time the lugs just need to be pressed inwards and the aeroblade will pull away from the arm.
Except ... they are normally very stiff. The best method is to have one person pull on the blade
while a second presses both lugs towards each other with some small M6 bolts.
The new blade then slides straight in.
There are 2 excellant Russian videos of the change-over near the bottom of this page -
http://kojamehed.ee/range-rover-vogue-l322...lades.html
Once you know how it is oh so easy !
bye 2003 TD6, EGR delete, vortex crankcase breather update, performance chip, UHF 2 way, Android head unit, crash camera on dash, always-on rear view camera to mirror screen, LED DRL`s, Electric trailer brake controller. FSR replaced. Pulling 3T caravan all about Australia
Post #537856 19th Dec 2019 7:23am
neilly
United Kingdom 2011 Range Rover Autobiography TDV8 Baltic Blue
Just replaced mine with the HQ wipers, replaced them with the arms in situ.
Typically the drivers side was a right PITA to get the original clip off of the end of the arm, but it came eventually.
Looking forward to seeing how they work compared to the originals.
Thanks
Post #538101 21st Dec 2019 1:44pm
DrRob
The HQ ones have been excellent so far on mine in the last 12 months. Stick a towel on the windscreen when doing the work to avoid any smashes! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #538104 21st Dec 2019 2:28pm
Poprivit
United Kingdom 2010 Range Rover Vogue SE TDV8 Ipanema Sand
Replaced my tired original style with some HQ ones and so far very impressed. Need to do a longer run at motorway speeds but definitely worth the money.
Post #542001 26th Jan 2020 9:33pm
GGDR
Admittedly fiddly fitting them first time, but after three years on my first HQ's I fitted a replacement new pair today and it took all of two minutes. i.e. a minute per side. Thumbs Up
Yes they lasted very well too.
Looks much cleaner:
 Cheers, Greg
Post #542011 26th Jan 2020 10:38pm
DrRob
Clean them regularly with some WD40 on a rag / paper towel Thumbs Up
Greg - your scuttle looks like new Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #542012 26th Jan 2020 10:46pm
GGDR
Sonnax tyre gel Rob Thumbs Up
Excellent on all the black plastics. Cheers, Greg
Post #542013 26th Jan 2020 10:47pm
DrRob
Might try some. Last long enough? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #542014 26th Jan 2020 10:55pm
GGDR
Lasts longer than back to black type stuff on the plastics. Thumbs Up
Lasts pretty well on the tyres too.
Only problem is that I wash the wheels often to try and win the brake dust war.
EBC green pads on the front has reduced the dust significantly btw.
. Cheers, Greg
Post #542016 26th Jan 2020 11:04pm
DrRob
This stuff? Ordered Thumbs Up
https://rover.ebay.com/rover/0/0/0?mpre=ht...3830473685 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #542669 1st Feb 2020 6:04pm
GGDR
That's the one Rob. Thumbs Up
Geez it's gone up since I bought mine.
Lasts me a year though Thumbs Up
I find best to apply with a sponge.
It's gooey though so it keep the bottle and sponge in a little bag to isolate the goo!
We're proper off-topic now!
. Cheers, Greg
Post #542671 1st Feb 2020 6:18pm
DrRob
Cheers Thumbs Up
It’s all related somehow Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #542677 1st Feb 2020 7:07pm
pcourtney
very impressed with these HQ Aero Dynamics Very Happy
https://www.hq-automotive.co.uk/eng_m_By-V...93420.html
bought from Auto Lighting £16.44 delivered
https://www.auto-lighting.co.uk/PARTS-CONF...Cat3=41967
install video pretty much spot on ( so will be much easier to replace in years to come Smile
&feature=youtu.be
Post #542697 1st Feb 2020 10:04pm
DrRob
Those are the ones I fitted. Bought off eBay Thumbs Up
https://rover.ebay.com/rover/0/0/0?mpre=ht...1738271428
They also look so much better that originals Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #542734 2nd Feb 2020 9:56am
