Home > Maintenance & Mods (L322) > Aero Front Windshield Wipers Fitted |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35377 |
a great simple idea that is craig
13th Dec 2014 10:55am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Craig
13th Dec 2014 10:57am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7815 |
Just ordered some from the link that Smutt posted. The Continental ones.
19th Dec 2014 10:25pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
19th Dec 2014 10:33pm |
kevieb Member Since: 08 Nov 2014 Location: east sussex Posts: 1 |
Hello everyone i am new to this site . I have just fitted the ebay wipers from bolt on bits and they do fit but i was not impressed with the clip that holds them to the arm.If the button that locates in the wiper arm was just a bit longer i think it would make them more secure.As to noise there is none but i have not had the chance to try them in heavy rain yet. I also broke the plastic clip on the near side it just fell apart as i removed the blade.Can i buy this insert or does it come with new blades such as bosch 808? Better to remain silent and a thought a fool than to speak and remove all doubt. |
21st Dec 2014 12:17pm |
Arkle Member Since: 17 Aug 2014 Location: Cheshire Posts: 173 |
Hi Nick, Which ones clunked? The Continental ones. http://www.ebay.co.uk/itm/231202190017?clk...rmvSB=true Or the ones from Advanced Factors? http://www.advancedfactors.co.uk/bv2626s-l...6114-p.asp TIA, Paul. |
20th Feb 2015 11:00am |
the AF ones are the conti jobbys Paul. ... - .- -.
20th Feb 2015 11:37am |
Thanks, Stan.
20th Feb 2015 1:51pm |
apologies Paul, the first batch supplied by AF were conti's but they sell a different make now.. ... - .- -.
20th Feb 2015 2:06pm |
No worries. I'll order the Conti's. |
20th Feb 2015 2:12pm |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
Well like some of the others, I jumped on a band wagon. Bought mine to eliminate a clunking noise at the top of the swipe on the drivers side. Alas it wasn't long after my purchase that ppl commented the clunk remained. Mine are wrapped still in the garage. I have cleaned the rubbers on the genuine LR's and will see how they go. I am a bit confused with how and why it's seemingly quite awkward to swap/upgrade your wiper blades?
20th Feb 2015 2:52pm |
When are these due back in stock please?
20th Feb 2015 3:00pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1513 |
@ Nick, I cured a clunk in mine by removing the wiper arms and re-setting them per the diagram Stan shared. the underneath part where the cast alloy grooved part sits on the spindle is convex to allow different angles of fitting. I've also seen people twist the wiper arms to get a flatter blade which is less likely to clunk at either extreme of travel.
20th Feb 2015 3:06pm |
Continental wipers fitted and all is good so far. Zero clunk when out in drizzle a couple of days go.
9th Mar 2015 12:15am |
