Home > Maintenance & Mods (L322) > Auto 'dipping' passenger wing mirror?
Page 3 of 3 <123
Bushy513
United Kingdom 2003 Range Rover Vogue Td6 Monte Carlo Blue
I have the opposite problem with mine. It goes down when reverse is selected but then forgets to go back up sometimes.. Yawn Bushy
2003 RR Vogue Monté Carlo Blue
Post #261747 27th May 2014 9:43pm
iphs
England 2003 Range Rover Vogue Td6 Buckingham Blue
Still didn't work for me. I have full movement on both mirrors, up-down-in-out, just don't seem to memorize the settings.
Post #261761 27th May 2014 10:27pm
andy180
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
iphs sounds exactly the same as my issue Whistle perhaps something is required on the diagnostics - Definitely no issue with motors etc as far as I can see Thumbs Up Now: BMW 640d M Sport, Alpine White
Gone: Range Rover 4.4 V8 Vogue, Zambezi Silver, Charcoal Oxford Leather
Also: Mk1 Audi TT 1.8T Quattro, Brilliant Black
[URL=]
[/URL]
Post #261769 27th May 2014 10:52pm
There's a couple of things you could try.
The drivers door mirror can also be set in different positions and the positions stored on the memory buttons M1, M2 and M3.
Set the drivers door mirror and store the position in the memory as above.
Then physically move the mirror to a different position using the door controls.
Press M1 with the ignition on and the mirror should drive to the stored position.
This would show whether or not the memory function works at all.
Next is a battery disconnect and reconnect and then try setting the reverse function again.
Lastly the car needs plugged into a diagnostic system to check if a fault is logged in the Body Control Module.
If the mirrors cannot be made to work then I have no idea, sorry. Thumbs Up
Post #261810 28th May 2014 8:41am
Page 3 of 3 <123
