Home > Maintenance & Mods (L322) > Auto 'dipping' passenger wing mirror? |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 |
..............anyway instructions are on the top of the sun visor 5.0 supercharged autobiography
25th May 2014 10:02am |
.........................so how many thought "I don't remember seeing that" .............and went out to check 5.0 supercharged autobiography
25th May 2014 10:56am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
You have to store the "up" position of the mirror and the "down" position of the mirror using the seat memory button.
26th May 2014 4:47pm |
Ok try again. Set the seat and mirrors to your desired positon enter into seat memory 1, now push the mirror switch towards the drivers side mirror, select reverse and hey presto. 5.0 supercharged autobiography
26th May 2014 4:53pm |
................Previous posts are what happens when you have more than one model of Range Rover 5.0 supercharged autobiography
26th May 2014 4:54pm |
iphs Member Since: 07 May 2014 Location: Norfolk Posts: 198 |
That didn't work on mine |
26th May 2014 6:04pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7793 |
Not much in my manual ;
26th May 2014 6:22pm |
Well it works on mine ok.
26th May 2014 7:53pm |
andy180 Member Since: 26 Aug 2010 Location: scotland Posts: 509 |
Ok so I set the seats various times and my passenger mirror doesn't seem to move at all with the memory buttons When I change the seat position the steering wheel moves, the seat moves, the drivers mirror moves..... but the passenger mirror doesn't I can only assume this is something to do with why my mirror is not dipping Now: BMW 640d M Sport, Alpine White
27th May 2014 8:00am |
If I get time this morning I will check the procedure I used on my car and post it for you so you can try what works for me. |
27th May 2014 8:11am |
I look forward to that
27th May 2014 8:20am |
Right this is how I do it and I've just checked and it works ok on my car.
27th May 2014 1:14pm |
Nice day for it thank you for your detailed response. I've been out and tried that a few times now and it definitely isn't for working. The mirror is operational with the door pack and the motor seems to be perfectly strong and operates as it should. As do my memory settings otherwise and I have the switch in drivers position Now: BMW 640d M Sport, Alpine White
27th May 2014 5:57pm |
absolutely brilliant................. 5.0 supercharged autobiography
27th May 2014 5:59pm |
