Home > Maintenance & Mods (L322) > Super Charger Aux water pump |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
firstly, can you fill in your car profile so we know what model/year you have.
19th May 2014 11:08am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
Yes you need to pull the headlight for access |
19th May 2014 11:09am |
Av_dave Member Since: 31 Dec 2012 Location: Stourbridge West Midlands Posts: 109 |
Yes can confirm you need to remove the grill then headlight it's pretty straight forward. Also I would recommend replacing the pump after re pinning it. The difference between theory and reality is that in theory it will work. |
19th May 2014 11:41am |
why would you recommend replacing the pump ?
19th May 2014 11:45am |
If you look at the Tsb from landrover (it's on here somewhere) it recommends replacing it. As I suppose it's been running backwards all it's life and I would of thought it suddenly changing direction it's not going to last very long I changed mine the other month when I re pinned it. But after testing the old one it wasn't even working anyway. The difference between theory and reality is that in theory it will work. |
19th May 2014 11:50am |
Duke Thrust Member Since: 07 Jun 2010 Location: Gloucestershire Posts: 59 |
Thanks for the responses guys, appreciated! |
19th May 2014 11:56am |
