![]() | Home > Maintenance & Mods (L322) > Super Charger Aux water pump |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35494 ![]() ![]() |
firstly, can you fill in your car profile so we know what model/year you have.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1353 ![]() ![]() |
Yes you need to pull the headlight for access |
Av_dave Member Since: 31 Dec 2012 Location: Stourbridge West Midlands Posts: 109 ![]() ![]() ![]() |
Yes can confirm you need to remove the grill then headlight it's pretty straight forward. Also I would recommend replacing the pump after re pinning it. The difference between theory and reality is that in theory it will work. |
why would you recommend replacing the pump ?
If you look at the Tsb from landrover (it's on here somewhere) it recommends replacing it. As I suppose it's been running backwards all it's life and I would of thought it suddenly changing direction it's not going to last very long I changed mine the other month when I re pinned it. But after testing the old one it wasn't even working anyway. The difference between theory and reality is that in theory it will work. |
Duke Thrust Member Since: 07 Jun 2010 Location: Gloucestershire Posts: 59 ![]() ![]() ![]() |
Thanks for the responses guys, appreciated! |
