Home > Maintenance & Mods (L322) > Super Charger Aux water pump
Duke Thrust
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Guys,
I've got the incorrect wiring problem on my S/C (found after the reduced performance message). There doesn't seem to be enough slack on the loom to lift the connector far enough up to swap the pins over.
Looks like I have to remove the headlight for easy access - is this the case?
Post #260233 19th May 2014 11:03am
firstly, can you fill in your car profile so we know what model/year you have.
secondly , removing the headlight unit is very easy . ... - .- -.
Post #260235 19th May 2014 11:08am
dingg1
Yes you need to pull the headlight for access
Post #260237 19th May 2014 11:09am
Av_dave
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Yes can confirm you need to remove the grill then headlight it's pretty straight forward. Also I would recommend replacing the pump after re pinning it. The difference between theory and reality is that in theory it will work.
Post #260247 19th May 2014 11:41am
dingg1
why would you recommend replacing the pump ?
it should still be serviceable even if it has been running in the wrong direction
Post #260249 19th May 2014 11:45am
Av_dave
If you look at the Tsb from landrover (it's on here somewhere) it recommends replacing it. As I suppose it's been running backwards all it's life and I would of thought it suddenly changing direction it's not going to last very long I changed mine the other month when I re pinned it. But after testing the old one it wasn't even working anyway. The difference between theory and reality is that in theory it will work.
Post #260252 19th May 2014 11:50am
Duke Thrust
Thanks for the responses guys, appreciated!
Post #260256 19th May 2014 11:56am
