Home > Technical (L322) > Engine not going past 2000RPM when depressing accelerator
Diver Bryn
United Kingdom 2005 Range Rover Vogue Td6 Tonga Green
Hi My Wife just rang me (I am working here in Libya) car is losing power won't go past 2000Rpm! Ok I said, the hand brake is off...Yessss She replied :-)
Good! when she fully pressed the accelerator on the odd occasion she has no power build up.
I quickly established the Engine power is normal as she fully red lined it for 5 seconds to test engine. Engine fine.
Looks like communication problem from pedal to engine management system to push out the rev's??
Any one else experienced this. I never let the diesel tank go below half full to suck in contaminates in fuel line.
Car oil and filter changed every 10,000 miles regardless if service light said 14,000. Never had this issue in 120,000 miles of driving.
Thoughts? Diver Bryn
Previous Transport:
Honda CB250n
Toyota Starlet
Renault Fuego 2 ltr TX
Fuego Turbo
BMW 528i
Escort RS Turbo
Capri 2.0 L Ghia
Kawasaki GT750 P4
Mini Metro
Ford XR2
Volvo 740 TDi Estate
Mondeo Tdi
Volvo V70 Tdi
Mercedes E300 TDI
Mercedes E320 Cdi
Mercedes S320 Cdi
Land Rover Discovery 3 TDV6
Mini Cooper Diesel
Mercedes Vito Van 111
Range Rover TD6
VW Golf 2ltr GTD 2015 Year
2016 Audi Q7 Sline 3ltr 272Bhp
Post #255546 22nd Apr 2014 1:03pm
Diver Bryn
Sorry Car is a 2005 facelift model year Range Rover Vogue TD6 3 litre diesel. Diver Bryn
Previous Transport:
Honda CB250n
Toyota Starlet
Fuego Turbo
BMW 528i
Escort RS Turbo
Capri 2.0 L Ghia
Kawasaki GT750 P4
Mini Metro
Ford XR2
Mondeo Tdi
Volvo V70 Tdi
Mercedes E300 TDI
Mercedes E320 Cdi
Mercedes S320 Cdi
Mini Cooper Diesel
Range Rover TD6
Post #255547 22nd Apr 2014 1:05pm
Any warning lights on? EML for example? Got - 2017 SDV8 Autobiography in Loire Blue
Post #255548 22nd Apr 2014 1:12pm
GraemeC
Not the same symptoms but possibly the same cause....
I had a Fiat Coupe which had a dodgy connection to the throttle position sensor - when the connection came loose, it used the idle at 2,000rpm (very embarrassing at lights Whistle )
If you know a garage with the tools to read live data, I'd start by checking out the readings from the TPS as the accelerator is depressed 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #255554 22nd Apr 2014 1:53pm
Diver Bryn
Many thanks it was at lights and roundabouts She mentioned the power lag. Diver Bryn
Previous Transport:
Honda CB250n
Toyota Starlet
Fuego Turbo
BMW 528i
Escort RS Turbo
Capri 2.0 L Ghia
Kawasaki GT750 P4
Mini Metro
Ford XR2
Mondeo Tdi
Volvo V70 Tdi
Mercedes E300 TDI
Mercedes E320 Cdi
Mercedes S320 Cdi
Mini Cooper Diesel
Range Rover TD6
Post #255565 22nd Apr 2014 2:33pm
Diver Bryn
Will enquire tonight about warning lights ;-) Diver Bryn
Previous Transport:
Honda CB250n
Toyota Starlet
Fuego Turbo
BMW 528i
Escort RS Turbo
Capri 2.0 L Ghia
Kawasaki GT750 P4
Mini Metro
Ford XR2
Mondeo Tdi
Volvo V70 Tdi
Mercedes E300 TDI
Mercedes E320 Cdi
Mercedes S320 Cdi
Mini Cooper Diesel
Range Rover TD6
Post #255569 22nd Apr 2014 2:45pm
Mark.abersoch
United Kingdom 2010 Range Rover Vogue SE TDV8 Bonatti Grey
Try the fuel filter. It may be blocked or failing that it may be the low pressure fuel pump.
Exactly the same happen to mine on Friday. It had a full service in June last year including all the filters. Plugged in with autologic and it showed they the fuel pressure was down to about 150-180.
It's still drivable just. I got home by fettling the peddle so not to ask to much and it tootled along fine.
I'm just about to get a pump ordered and fitted as I type this.
I'll let you know if this fixes it but from the readouts given it's pointing in this direction. 2009 TDV8 Vogue SE - Bonatti Grey
Post #255575 22nd Apr 2014 3:34pm
I hope its not the Turbo failed.
Post #255578 22nd Apr 2014 3:44pm
Diver Bryn
mark.abersoch wrote:
try the fuel filter. it may be blocked ...............
spot on mark! my mechanic has just confirmed its the fuel pump near the tank that has failed. he even came prepared with pumps and filters. relieved to say the least. my thoughts were initially it was the turbo or worse...;-0 Diver Bryn
Previous Transport:
Honda CB250n
Toyota Starlet
Fuego Turbo
BMW 528i
Escort RS Turbo
Capri 2.0 L Ghia
Kawasaki GT750 P4
Mini Metro
Ford XR2
Mondeo Tdi
Volvo V70 Tdi
Mercedes E300 TDI
Mercedes E320 Cdi
Mercedes S320 Cdi
Mini Cooper Diesel
Range Rover TD6
Post #255581 22nd Apr 2014 4:30pm
mjdronfield
So when you say spot on, what you mean is it was the pump not the filter......... Whistle
Seriously, that's cracking news.
Much respect for some if your previous cars........ Smile 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #255588 22nd Apr 2014 5:04pm
Diver Bryn
Excellent fix cheers for the technical input fella's. Saved me a few hundred quid from the sharks in the Land Rover dealership at Stratstone's. :-)
Problem was the intermediate fuel filter between the tank and engine. Changed all filters and back to its normal good running self again. Diver Bryn
Previous Transport:
Honda CB250n
Toyota Starlet
Fuego Turbo
BMW 528i
Escort RS Turbo
Capri 2.0 L Ghia
Kawasaki GT750 P4
Mini Metro
Ford XR2
Mondeo Tdi
Volvo V70 Tdi
Mercedes E300 TDI
Mercedes E320 Cdi
Mercedes S320 Cdi
Mini Cooper Diesel
Range Rover TD6
Post #261691 27th May 2014 6:05pm
hiramk
United Kingdom 2006 Range Rover Vogue Td6 Barolo Black
I had the low pressure pump fail on me, it wouldn't go over 30mph, not what you want on the A1 Monday morning. About an hour prior to it loosing power on the A1 while travelling through the Yorkshire Dales I noticed a kind of blip/engine flutter/gear change hesitation when it changed up a gear going up steep hills. It felt a little like it went from 3rd to 4th and then 3rd to 4th again. Towed to the dealer and £365 later all was well. The dealer was Ribblesdale in Settle, nice bunch of people with proper old style service, not the artificial meet and greet I get down the Skoda dealer I wish they wouldn't bother 'cause they don't give a monkeys really, they've just been on "THAT" course.
Post #317935 13th Mar 2015 9:54pm
