Home > Maintenance & Mods (L322) > hid light flickering
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
i've fitted hid kit to the fog lights of 2007 FFRR; light looks good but the left one goes off by itself from time to time. this light also seems to be a bit bluer light than the other side
Wondering whether that could be due to a bad connection or could it be due to the failure of either the bulb or the ballast?
Post #254766 16th Apr 2014 7:40pm
are they chinese jobbys cos they tend to get faulty ballasts and bulbs.. ... - .- -.
Post #254770 16th Apr 2014 7:49pm
And the power system on a FF played merry hell with cheap HID kits... Embarassed
Post #254771 16th Apr 2014 7:53pm
vnitos
caught out Laughing they actually are - my sons use the same (h1 and h4) in their respective cars without having any hassles.
so i thought i will use the same
these lights are actually quite good when they're working ; but ...
Post #254773 16th Apr 2014 7:54pm
vnitos
any suggestions as to which brand, e.g. phillips,i should use. would like to get hids4u's kit but time won't allow that as I'm going on a 4,000km trip next week and want to have the lights in before then.
btw phillips confirmed that theirs is not necessarily canbus compatible
Post #254774 16th Apr 2014 7:57pm
try swapping the bulb or ballast with the working side to see which is faulty..
i'd also avoid hid's and get cree leds.. ... - .- -.
Post #254776 16th Apr 2014 7:59pm
vnitos
"and get cree leds.."
@stan - will the advantage of using cree leds over hid kit include improved lightning up of the road, etc.
Post #254777 16th Apr 2014 8:03pm
High quality LED kit/replacement light... i.e. Osram do a very nice bright LED/DRL light kit...
Thats what i use Thumbs Up
Post #254778 16th Apr 2014 8:05pm
if you want maximum forward light projection then halogens are the best bet, you can get 'white' type bulbs that look very close to the 6000k leds/hids..
but you might want to consider something like mine which that chappy above [Craig] supplied..
they are very bright and i use them as drls rather than fogs,, ... - .- -.
Post #254787 16th Apr 2014 8:52pm
vnitos
lights not flickering anymore - solution: put a canceller on as the ballasts are not compatible with the Canbus system of the Range Rover
will see how it works on my 4500km trip next week
Post #254935 18th Apr 2014 8:35am
What is a canceller?
Post #254940 18th Apr 2014 9:03am
resister probably ... ... - .- -.
Post #254950 18th Apr 2014 9:38am
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
or even a resistor Stan Whistle 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #254952 18th Apr 2014 9:40am
ballocks....... Mr. Green ... - .- -.
Post #254953 18th Apr 2014 9:41am
Laughing Laughing Laughing ignoramous innit Rolling with laughter Rolling with laughter Rolling with laughter
Post #254954 18th Apr 2014 9:41am
