![]() | Home > Maintenance & Mods (L322) > hid light flickering |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35649 ![]() ![]() |
are they chinese jobbys cos they tend to get faulty ballasts and bulbs.. ... - .- -.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
And the power system on a FF played merry hell with cheap HID kits... |
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 ![]() ![]() ![]() |
caught out |
any suggestions as to which brand, e.g. phillips,i should use. would like to get hids4u's kit but time won't allow that as I'm going on a 4,000km trip next week and want to have the lights in before then.
try swapping the bulb or ballast with the working side to see which is faulty..
"and get cree leds.."
High quality LED kit/replacement light... i.e. Osram do a very nice bright LED/DRL light kit...
if you want maximum forward light projection then halogens are the best bet, you can get 'white' type bulbs that look very close to the 6000k leds/hids..
lights not flickering anymore - solution: put a canceller on as the ballasts are not compatible with the Canbus system of the Range Rover
What is a canceller? |
resister probably ... ... - .- -.
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
or even a resistor Stan |
ballocks....... |
