Home > General > Biggest fuel top up |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Oh Greg, that's not trying at all sir... There is something like 8 or 9 litres in the pipework too
13th Apr 2014 9:53am |
Greg66 Member Since: 10 Nov 2010 Location: London Posts: 84 |
110! I am impressed - at your nerves of steel! I might be prepared to try running it dry doing laps around the forecourt, but not otherwise.
13th Apr 2014 10:21am |
Im sure they do sir yes... Mine needed a new tank pump hence the running it low
13th Apr 2014 10:25am |
Chauch Member Since: 09 Feb 2014 Location: Beds Posts: 303 |
The last owner claimed that he had run out in mine with 70 miles showing on the range so have been nervous of running it too low.
13th Apr 2014 10:51am |
The FFRR has a tank capacity of 106 litres according to the handbook. Add in a bit for the various pipes, filter etc and probably 110 all told for a completely dry vehicle.
13th Apr 2014 12:11pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35278 |
the pump might have said 99.44 litres Gregg but can you be sure that was the amount that went in the tank.... ... - .- -.
13th Apr 2014 1:22pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2575 |
^ what are you insinuating Stan |
13th Apr 2014 1:34pm |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
Bring back gallon cans to buy fuel in, not these new fangled pumps!! |
13th Apr 2014 6:04pm |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 |
I regularly pull in to the petrol station with only dashes on the range indicator...
13th Apr 2014 7:37pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
I've let it get pretty low at times. I'm 4 minutes from the US/Canada border and petrol is a LOT cheaper over there. Filling up in the States can be compared with LPG in the UK: much cheaper and the car still works.
13th Apr 2014 9:20pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
Being a relative newbie I see I am also a bit chicken as I refill just below the quarter - my old p38 used to run out on the quarter the needle used to register full for a long time after a fill up though |
14th Apr 2014 12:55pm |
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 |
i've learnt the hard way of not running the car that low - fuel pump in SA cost me R10k (GBP560) - after that i made (and is still doing that) of filling up when it reaches ¼ tank |
14th Apr 2014 2:02pm |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 |
I forgot to check most of the time but once I had it at 0 miles for about ten miles when I got it and it took 165 quid to fill to brim now I let it go to half then 60 to 70 is easier to stump up _____________________________________________________
15th Apr 2014 7:22am |
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305 |
I've often in my previous RR driven on 0 for more the than a few miles. Once or twice I've ran out of fuel, using just arriving home!
15th Apr 2014 8:10am |
