Home > General > Biggest fuel top up
Greg66
2006 Range Rover Supercharged 4.2 SC V8 Santorini Black
Biggest fuel top up
I managed 99.44 litres yesterday, supposedly into a 100 litre tank. Even took a photo!
IIRC, 0.56 litres is almost exactly a pint. Not much for a FF to live off...
I decided to stop in Dijon for lunch and petrol. The needle was below the lowest marker, and the range showed 25 miles. However, once I came off the autoroute and started pootling in traffic it dropped fast - down to 13 miles within 4 miles off coming off the autoroute! Quite relieved to see a petrol station.. Range Rover 4.2 SC
AM V12VS
Porsche 991.1 Turbo S
Mini JCW conv
Post #254176 13th Apr 2014 9:50am
Oh Greg, that's not trying at all sir... There is something like 8 or 9 litres in the pipework too Laughing
I have before got around the 110ltr mark in a 100ltr tank'd ffrr sir Bow down
Post #254181 13th Apr 2014 9:53am
Greg66
110! I am impressed - at your nerves of steel! I might be prepared to try running it dry doing laps around the forecourt, but not otherwise.
Do the petrols and diesels have the same size tank? Range Rover 4.2 SC
AM V12VS
Mini JCW conv
Post #254191 13th Apr 2014 10:21am
Im sure they do sir yes... Mine needed a new tank pump hence the running it low Thumbs Up
Rarely gets below half these days Thumbs Up
Post #254192 13th Apr 2014 10:25am
Chauch
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
The last owner claimed that he had run out in mine with 70 miles showing on the range so have been nervous of running it too low.
Last weekend, with the needle at about an eighth of a tank and 70 miles on the range, I brimmed it and only got about 85 litres in.
Surely worth the risk of delving lower on the fuel gauge if you guys are getting 100+ in?? 4.2 Supercharged Vogue SE
Post #254195 13th Apr 2014 10:51am
mzplcg
The FFRR has a tank capacity of 106 litres according to the handbook. Add in a bit for the various pipes, filter etc and probably 110 all told for a completely dry vehicle.
It's a brave man who runs down that low to get 100 litres in. I get a nervous twitch when the light comes on. Laughing
Post #254204 13th Apr 2014 12:11pm
the pump might have said 99.44 litres Gregg but can you be sure that was the amount that went in the tank.... ... - .- -.
Post #254215 13th Apr 2014 1:22pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
^ what are you insinuating Stan Whistle
Post #254216 13th Apr 2014 1:34pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Bring back gallon cans to buy fuel in, not these new fangled pumps!! Laughing
Post #254262 13th Apr 2014 6:04pm
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
I regularly pull in to the petrol station with only dashes on the range indicator...
The most I have managed is around the 110L mark too.
I find it hurt the pocket a little too much to refuel to often so I wait for one big hit! 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #254270 13th Apr 2014 7:37pm
RR2008HSE
I've let it get pretty low at times. I'm 4 minutes from the US/Canada border and petrol is a LOT cheaper over there. Filling up in the States can be compared with LPG in the UK: much cheaper and the car still works. Mr. Green
I did manage to stall my V8 Disco1 300m from the petrol station one day. I went around a roundabout, and the remaining teaspoon or so of fuel disappeared! Shocked
Unbelievably, three petrol stations together and none had a gas can I could borrow for five minutes. Evil or Very Mad Fortunately, a fellow motorist helped me out and she fired up immediately once that was some petrol in there.
Post #254291 13th Apr 2014 9:20pm
Sandyt
Being a relative newbie I see I am also a bit chicken as I refill just below the quarter - my old p38 used to run out on the quarter the needle used to register full for a long time after a fill up though Mr. Green
Post #254392 14th Apr 2014 12:55pm
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
i've learnt the hard way of not running the car that low - fuel pump in SA cost me R10k (GBP560) - after that i made (and is still doing that) of filling up when it reaches ¼ tank
Post #254398 14th Apr 2014 2:02pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
I forgot to check most of the time but once I had it at 0 miles for about ten miles when I got it and it took 165 quid to fill to brim Sad now I let it go to half then 60 to 70 is easier to stump up Thumbs Up _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #254495 15th Apr 2014 7:22am
theanswers
Ireland
I've often in my previous RR driven on 0 for more the than a few miles. Once or twice I've ran out of fuel, using just arriving home! Laughing
Or more than likely the issue arrises in the morning, it then won't start.
Post #254498 15th Apr 2014 8:10am
