Home > Maintenance & Mods (L322) > 2010/2012 facelift conversion - my step by step guide
Page 5 of 12 <123 456 ... 101112>
Alun1976
United Kingdom 2002 Range Rover HSE 4.4 V8 Zambezi Silver
Can anyone help with my above question? When fitting the 2010 lights and doing full front end conversion the headlamp interferes with the air duct from the air filter housing to the inner wing. I've had to temporarily remove it , how did you guys overcome this product?
Thanks
Post #355272 4th Nov 2015 9:46am
i believe a K&N filter has to be fitted on the petrol conversions.... ... - .- -.
Post #355278 4th Nov 2015 10:13am
Alun1976
Thanks for the reply. It isn't the actual filter, nonor the filter housing but instead the air intake ducting that the light fouls with. I'm just wondering if their is a different design air intake ducting available.?
Post #355281 4th Nov 2015 10:37am
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
There isn't a different design of duct, the duct and housing have to be removed and changed to a K&N filter
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos ➞ YouTube.com/RangeRoverOwner
Post #355282 4th Nov 2015 10:40am
Alun1976
Thanks Matt.
Can you please direct me which one I will need if I decide to completely remove the original airbox.
Post #355285 4th Nov 2015 10:52am
mattstevenson2005
This is the type you need, I have this k & n fitter. A nice side effect of changing the filter is you get a big more of s gurrrrr from the engine under acceleration haha
Matt Current
Post #355334 4th Nov 2015 7:28pm
RangeK1D
Canada 2004 Range Rover HSE 4.4 V8 Zambezi Silver
Headlight Wiring & Bumper Support
Hey Matt, great write up!
I did the conversion as well, got everything down electrically except for one thing; I am trying to figure out how to manipulate the wiring so when my vehicle has it's DRL's turned on the Angel Eyes turn on.
Right now for DRL function the Angel Eyes don't turn on; rather I get a pesky yellow halogen bulb that comes on as my full time DRL. If I turn the Light Knob from the "Off" position to Park Light or Low Beam, the Angel Eyes come on, so any ideas?
Also I still haven't attached the bumper brackets properly (kind of doing without them) which leaves a slight gap between the bumper and the fender, so I am eager to be rid of this gap, in order to that should I have these plastic brackets some how welded on? Should I use your fiber glass idea (which I still don't have a clue as to how it works Laughing ), people have even suggested bolting on the bracket (don't know where the bolts would go but meh).
Any advice is greatly appreciated,
Thanks. Zambezi Silver Range Rover (2010 Autobiography Facelift)
Java Black Range Rover 4.2SC (Westminster)
Mercedes Benz GL450 4Matic (X164)
Mercedes Benz E320 CDI (W211)
Mercedes Benz 300SDL (W126)
Lexus LX470 (J100)
Lexus GX470
Audi A8L (D3 Chassis)
Post #364707 31st Dec 2015 8:23pm
mattstevenson2005
Hi Rangie
You can't natively use the angel eyes as DRLs as they were never designed to function like that as standard and on your model of car the halogen lamp is what is used as the DRL. The only way I can see to enable them to function as DRL is to find an ignition live and wire that directly into the Angel eyes so they function all the time. I have toyed with this idea myself but haven't got round to doing it.
With regards to the wings you either use your existing wings and cut out the old bracket mounts with a grinder and fibreglass (mix an epoxy resin and paste it on to sheets of fibreglass) to secure the new brackets in place or you have to purchase the later style wings that already have the mounting holes for the 2010+ wing brackets and bolt them on.
Hope this helps
Matt Current
Post #364919 2nd Jan 2016 5:08pm
RangeK1D
Hey thanks for the reply Matt, okay yeah I guess I'll try and find a live wire and might just end up purchasing 2006+ Zambezi Silver wings. Also I was looking around and folks were mentioning that we can use the faultmate tool to turn the DRL's on, not 100% sure if that applys to our situation but worth a gander.
Cheers Zambezi Silver Range Rover (2010 Autobiography Facelift)
Lexus LX470 (J100)
Lexus GX470
Post #364948 2nd Jan 2016 7:10pm
robbo770
Scotland 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Drl function is approx 2009 onwards, bar a software hack with GAP, Subject to the CJB having the function in 2006- motors Current vehicles
4.2 SC FFRR RSE 2010- facelift
Range Rover Evogue Dynamic Lux
Gone
Rejected RRS my14.5 nightmare
Disco B4 XXV convert
Freelander 06 SE
06 RFFRR 4.2 SC Vogue RSE
Audi A8 4.2Tdi Quattro (hated with a vengence!!)
54 FFRR 2005 model V8 4.4 Cobra Variant
53 Mitsubishi Shogun V6
Post #364953 2nd Jan 2016 7:47pm
mattstevenson2005
I have a faultmate and u can enable DRLs however on range rovers of that time the DRLs use the halagons not the side lights.
Matt Current
Post #364984 2nd Jan 2016 11:21pm
AKIS
2004 Range Rover Vogue Td6 Cairns Blue
Excellent writting that's make me to start considering to facelift my td6 model 04.In internet search i found a youtube video made by a company,in fast forward however,facelifting a similar car like mine and they fitted the new bumper directly to old crash bar without any modification.Are foglights in new bumper is such lower position that can be fitted so easy?
Keep on the nice work which of great assistance Thumbs Up
Post #366015 8th Jan 2016 11:40am
mattstevenson2005
You don't need to change the crash bar to fit the new bumper, you just have to replace the bracket that sits on top of the crash bar to the new type. The new fog lamps sit below the crash bar so there is no problems. Current
Post #366339 10th Jan 2016 11:10am
AKIS
Many thanks for your reply.I will go ahead and will follow exactly your steps.What i am caring for are the electrical conversions,for which have not special knowledges but gross fingers that will run smoothly
Once again many thanks
Post #366499 11th Jan 2016 12:40pm
AKIS
Hi all.Presently under facelift process of my 2004 to 2010 and wondering whether you can assist me to the following:
1.From old square headlights i have disconnected two connectors.The cables of the main/bigger one will be reconnected,as per drawing,with the new type connector.Wondering if the the second smaller connector will remain unconnected or what??
2.Re headlights washing system.When i took bumper off I saw that on armature are crossing 2 rubber hoses.Believe the one hose is routed to the other side headlight wiper's washing system.
The 2nd hose is for what?do i have to also remove it?
Your assistance will be most welcome
Many thanks
Post #375079 1st Mar 2016 11:59am
