![]() | Home > Maintenance & Mods (L322) > 2010/2012 facelift conversion - my step by step guide |
AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186 ![]() ![]() |
Hi to all.Upgrade from 04 to 10 after a week's efforts,due to lack of time and expertise,successfully completed thanks to site infos.
Any reply please |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
If the lights seem to be working ok but you are getting check bulb/light messages it sounds like the cold (engine off) or hot (engine on) monitoring. This is the ECU checking the voltage of the lights for any bulb that might be out. LED lighting uses such low power it will flag as a faulty bulb. By using diagnostic equipment such as the GAP IID tool you can turn off the checking (hot and cold monitoring) of the bulbs to get rid of the error messages.
Flashman many thanks for yr reply which noted |
jam220 Member Since: 08 Jun 2016 Location: Atlanta Posts: 31 ![]() ![]() ![]() |
Unnecessary quote removed
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2231 ![]() ![]() ![]() |
Guys do these look like the right sensors for the new front bumper seem cheap for 4 https://www.ebay.co.uk/itm/221867341063 |
There are some other sets on there with the trim for $80..i was going to use them but went with a diff option |
What do you mean with the trim don't these just push into the new bumper? Do these look correct as seem very cheap for 4 |
Another question - is it possible to switch on the cornering lights as I have these? |
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 ![]() ![]() ![]() |
I'd like to know if they are the correct parking sensors too as I have just bought 2010 front bumper as a start to my facelift. Also are they painted when fitted to the original bumper from factory? 2004 RR 4.4 V8 Autobiography |
i think i am going to bite the bullet and see -
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
If you already have the AFS cornering headlights and you buy the 2012 Corning headlights you can wire them up to work just follow the wiring diagram.
If o have a 2002 how do I know if I have cornering lights? |
You won't havecornering lights on a 2002 they weren't around until about 2007ish and they can't be retro fitted to earlier cars.
