Home > Maintenance & Mods (L322) > 2010/2012 facelift conversion - my step by step guide
Page 4 of 12 <123 45 ... 101112>
Chillb
United Kingdom 2008 Range Rover Vogue TDV8 Rimini Red
Matt hi
How you getting on with your internal entertainment system mod.
Question Porsche 993 Targa, Buick Skylark Convertable 1968
Post #326349 6th May 2015 2:06pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
mrblonde wrote:
Awesome guide Matt and convinced me to facelift rather than upgrade at a huge cost (the FF i mean, not the missus)
Just wish you was my neighbour Whistle
Glad you have found it useful!
If you need any help you can contact me directly
Matt
Post #326458 6th May 2015 10:48pm
mattstevenson2005
Chillb wrote:
Matt hi
Question
The entertainment project is one of those that has become a huge monster, i built the whole system based on a third party base software then decided that it was too limited to add new features so i decided to scrap it and rebuild it from scratch writing my own code which where all the delay has come from. I am also in the process of completely rebuilding my website and expanding its content massively which is also taking a lot of my time up.
I will post any updates and developments on the project and website on here and on my site.
Matt
Post #326459 6th May 2015 10:52pm
DannyH
England 2002 Range Rover HSE 4.4 V8 Zambezi Silver
Brilliant write up pal, car looks top dollar now Dan
2002 Zambezi Silver
Men And Motors RR Quote - It's like having wheels fitted to your living room!
Post #326468 7th May 2015 4:37am
Sharkey
United Kingdom 2003 Range Rover Vogue Td6 Java Black
Lighting mods
Hi. Great job in detailing the conversion. I've nearly finished mine and am having a few minor probs with the front lights. I tried the led conversion boxes without success (the backs worked a treat) both myself and the chap who provided them can't work out why they won't stop the fast flash and they make no difference to the side lights as they worked anyway! So I've ended up fitting Powerfull's 22 Ohm resistors and they fix the flash issue. I still have the "check front light" warning on the dash, everything works as it should just wondering if anyone has a work round or experienced the same issue... Thanks in advance! 2003 Vogue TD6 converted to black 2012 set up
Post #330654 2nd Jun 2015 7:33pm
I'm thinking about embarking on my CEC before winter really kicks in. I've got all the bits but the one thing I can't seem to find is a wiring diagram for MY06 onward headlights.
Is there any point in buying the Powerful plugs and wires, or is this just going to duplicate what I already have at the back of my headlight?
Does anyone have anything to go on?
Ta Got - 2017 SDV8 Autobiography in Loire Blue
Post #349198 24th Sep 2015 5:46am
If yours is a VSE Alan? It will have the correct plugs! Just need pinning out and wiring moving around sir Thumbs Up
Post #349202 24th Sep 2015 6:08am
It is Craig and I know I have the correct plugs, but I don't have the details of the rewiring I'll need to do. All the stuff I've read is only relevant to 2003-06 cars with the old style headlights.
If only I knew someone who would be so kind as to send me those details......... Whistle Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #349206 24th Sep 2015 6:59am
Remind me when I get home... I'll have a look and see if I have anything... Also, check with NickTDV8 as he did his, which is the same as yours... He may have something I sent him that he could send on Alan... Thumbs Up
Post #349209 24th Sep 2015 7:28am
Thanks Craig, much appreciated. Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #349226 24th Sep 2015 9:16am
Alun1976
United Kingdom 2002 Range Rover HSE 4.4 V8 Zambezi Silver
Great write-up. This will help me a lot with my conversion. Thanks Thumbs Up Thumbs Up
One question, do you or anyone have the Land Rover part numbers for the black 2012 headlights with AFS and without AFS?
Cheers Very Happy
Post #351778 12th Oct 2015 12:22am
have a look on microcat for the part numbers , link in the wiki.. ... - .- -.
Post #351810 12th Oct 2015 9:45am
Strider
Inspiring project Bow down
Post #351901 12th Oct 2015 6:41pm
Not much point in getting AFS headlights, as they won't work with adaptive headlight equipped cars <2010 AFAIK Got - 2017 SDV8 Autobiography in Loire Blue
Post #351903 12th Oct 2015 6:46pm
Alun1976
Grest write up Matt. This helped me a lot as I started my facelift conversion today. One thing I'd like clarifying that doesn't seem to have been mentioned before is, what did you do with your air intake pipe that runs from the air filter to the off side front wing? I've had to remove this duct as the new headlight fouled it. Is there a different air duct needed, one that provides more clearance for the drivers side headlight.
Cheers 👍
Post #352936 18th Oct 2015 6:26pm
