Home > Technical (L322) > IIDtool :) |
Hi Stan,
18th Feb 2014 6:13pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35412 |
thanks for the clarification Steve...
18th Feb 2014 7:14pm |
goncalo Member Since: 26 Apr 2013 Location: Portugal Posts: 170 |
Thanks Steve!
18th Feb 2014 7:16pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3836 |
Interesting set of posts, when I got my IIDTool I first used it to correct a low corner, then messed with heights. As mine is a 2007 as Steve points out you can only apply a blanket change which affects all heights i.e. 10mm lower (which mine is) is 10mm lower at Access, 10mm lower at Normal and 10mm lower at Extended. I did this because at the time you couldn't set the speed at which it lowers to a more appropriate value - things might have changed I will check if ever the Indy gives me my car back assuming they don't impound it because I can't pay the bill Geoff |
18th Feb 2014 7:26pm |
the idtool is vin locked so that wont work.. |
18th Feb 2014 7:44pm |
Paul_H Member Since: 17 Dec 2013 Location: Bracknell Berks Posts: 126 |
Time to put on them trousers and tell her who's boss
18th Feb 2014 8:06pm |
Actually, if you read the VIN Lock post in the New Products thread at the top of the technical forum, you'll see that this policy is completely changed with the introduction of firmware 3.0
18th Feb 2014 8:28pm |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
If I turn on daytime running lights which lights will actually come on the xenon headlight or the sidelight? Are they adjustable as to brightness or just on or off? FYI I have the adaptive bi-xenon lights. There is a difference between knowing your sh!t and knowing you're sh!t
18th Feb 2014 9:57pm |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 |
I have mine set at 80% |
18th Feb 2014 10:46pm |
BUSAKAZ Member Since: 18 Oct 2013 Location: DAVENTRY Posts: 4 |
Hi all, new on here my question is does the llD tool BT work on a nokia 1020. Many thanks Kaz 2003 TD6 1996 4.6 hse (gone) 2000 200 BHP Hayabusa |
19th Feb 2014 5:15pm |
only ios and android afaik..
19th Feb 2014 5:18pm |
Thanks Stan 2003 TD6
19th Feb 2014 5:22pm |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
This little beauty arrived this morning...Ģ270 from Island 4x4..Ordered Tuesday..great service.
28th Feb 2014 11:39am |
and now the fun begins... |
28th Feb 2014 12:23pm |
