Home > Technical (L322) > Turbo Gone?
Turbo's re worked in Latvia Shocked Shocked Shocked
I personally would not take the risk! Rolling Eyes
Give Dan @ Duckworths a shout for an OE quote, then work from there Whistle
Post #241240 9th Feb 2014 10:06am
my bad, lack of understanding of the subject shown...... Whistle There is nothing that can't be fixed with a hammer😜😜
Post #241265 9th Feb 2014 10:32am
Rolling Eyes Whistle Yawn Laughing
Post #241279 9th Feb 2014 10:54am
Orch
Yeh I noticed that after posting. Perhaps not then Laughing
Post #241280 9th Feb 2014 10:54am
mick-ne
England 2004 Range Rover Vogue 4.4 V8 Java Black
Here you go a police demonstration, lol
Post #241539 9th Feb 2014 9:29pm
Orch
Haha, yeh saw that a few weeks ago. I bet that entertained a few locals!
Post #241542 9th Feb 2014 9:32pm
Orch
Been thinking about this a lot and earlier I remembered two things that I had dismissed at the time without a second thought. Firstly Dad mentioned it had started dropping oil recently, just a tiny amount. At the time I thought well it is a Land Rover Laughing but now I'm thinking perhaps that's a seal going because of the high crank case pressure. Maybe even a turbo seal.
The second thing was that earlier yesterday I had to jump start it (ongoing drainage issue, hopefully the new Final Stage Resistor I fitted yesterday will cure it) and once it started I held the revs up a bit to get the alternator to put some juice into the battery. I remember thinking it was very hard to hold the revs without wanting to climb. Now I'm thinking I was lucky it didn't keep on climbing without my input!
With this is in mind I think it's time to stop where I am and call the pro's.
Will be back to update the thread when the results are in, nothing more annoying than finding a thread with no final answer! Thumbs Up
Post #241562 9th Feb 2014 11:07pm
Modern diesels easily run away when they can pull fuel from somewhere else as there is no way for the computer to shut the airflow off.
best thing to do is have something on hand that could block the intake on the egr valve and just remove the pipe from it and then start it. If the turbo was blow then you will feel all the oil coming out of that pipe and not have to worry about a runaway engine as the oil cant get into the inlet tract to the engine itself Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #241639 10th Feb 2014 12:45pm
Post #241650 10th Feb 2014 1:58pm
Orch
Well as promised back for an update. Turbo had indeed gone. Spannerman said we were lucky, 2 more miles and it could have caused serious damage. Recon turbo fitted and all now good. He did change the crankcase filter breather for me and said it needed changing but wasn't that bad.
Thanks for all your input guys Thumbs Up
Post #243595 19th Feb 2014 9:13am
mjdronfield
Excellent result then, given the smoke.
Shouldn't have to worry about the turbo or the breather again now.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #243601 19th Feb 2014 10:12am
Orch
Yep two less things to worry about for a while I guess!
Post #243602 19th Feb 2014 10:16am
