Home > In Car Electronics (L322) > Dash camera fitment
Page 2 of 8 <12345678>
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
I've fitted the same cam in my FF and it's located up behind the rear view mirror. It does seem to be the best one around at the moment. "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #239101 2nd Feb 2014 10:09pm
Trev18
United Kingdom 2005 Range Rover Vogue SE Td6 Zambezi Silver
I wonder if its worth waiting for the new version
Mini 0801 A7 & WDR
IN STOCK LATE FEBRUARY/EARLY MARCH. An upgrade to the Mini 0801. The Mini 0801 with Ambarella A7 chip and WDR makes this one of the best cameras going. It's increased performance in the dark due to the chip and WDR means you catch your journeys in crystal clear quality in the same discreet body. Check out the specifications below.
ALL FOR £95.00 From the site Stan mentions above..
Lens 6 Glass Lens
Processor A7-LA30 processor
RAM DDR3 RAM
Image Sensor AR0330 CMOS
WDR Yes
GPS Yes
Memory Support up to 32gb.
MPH or KPH Supports both
Trev Current Cars
(Sold) Range Rover TD6 05 Vogue SE - 85k - Zambezi Silver - Black Leather..
Kia Ceed (4) 1.6 - 33k - Silver
Previous.
VW Golf 2008 2.0 SDI (With Add Ons) - 109k Silver
Vauxhall Zafira 2.2 Petrol SRI - with Ex Pack 32k -Turquoise (traded for the FFRR)
Post #239124 2nd Feb 2014 11:12pm
Prop
I looked at fitting mine on the passenger side as it then pretty much disappears behind the rear view mirror. But I didn't like the idea of not been able to easily access it from the drivers side without having to move the rear view mirror etc.
I got mine from the link Stan mentioned, Joovuu. I preferred the idea of buying from a UK based seller, and at the time I bought mine back in late October Joovuu was pretty much the only place in the UK selling them.
Post #239143 3rd Feb 2014 1:55am
Prop
Trev18, if night video is important then I guess it might be worth waiting for the new version. But what attracted me to the 0801 was the good reviews and so far it has lived upto expectations, and if I'm honest its exceeded them for its daytime video quality.
I guess no one knows for sure how good the new model is going to be until its released and maybe someone does a side by side comparison or something. But the dash cam manufacturers seem to update there models at-least every year. I believe the 0801 only came out in April/May 2013.
Post #239144 3rd Feb 2014 2:06am
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Sounds about right a new model out Big Cry , anything with a chip in it seems to be old hat as soon as you buy one! Sound good the updated one mind Thumbs Up
I bought mine from E-prance via Amazon, took a few weeks to deliver.
@Prop, good to know that its working well Thumbs Up I had seen a few reviews not to good about the camera but mostly where in favour of this little cam for the price and quality of picture in daylight. Very Happy If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #239164 3rd Feb 2014 8:50am
this section on the dashcam site is pretty good , it lists the dashcam and gives a brief review of it,
http://dashcamtalk.com/
Post #239171 3rd Feb 2014 9:00am
Welshdragon
Up date on the Camera,
The camera seems to turn off after a while with the sd card only 3quarters full, been doing this for 2 days now. I think the problem is the firmware.
My old firmware number was 20131026, so now have up dated it to 20130924 and cleared the sd card, so hopefully it will now record as it should, other than that its been great, even night driving is not that bad either to be honest. If it dont work.......burn it!
Post #241921 11th Feb 2014 12:08pm
there has been problems with the cards on this model, i gather you've read the threads on this..
now you've had for a while , whats the video quality like ?
Post #241924 11th Feb 2014 12:18pm
Prop
Mine has been running with out issue since the end of October with a 32gb Samsung type 10 memory card, never had any problems the card filled up and then over writes oldest file as needed so its always basically near enough full.
I would suspect the type of memory card being used.
Post #241942 11th Feb 2014 2:01pm
Welshdragon
Stan, the camera picture quality is very good from low very bright sunshine to dark grim days, even the night time, headlights only are good enough for me you can see the road well enough, if there are street lights the quality will be better, no blury picture here on 1080p.
Play back on the lap top, well its good as the review techmoan said, no hesitation from one frame/file to the next when viewing a few files together.
So far so good IMO. Thumbs Up
Prop, I too have a 32gb card but its a class 6 from Samsung as I had read that the class 10 was to quick for the camera, also the manual says not to use the class 10 too!
What firmware are you on?
As my card has only one recording (driving to work) I'll have to wait to see if the firmware has sorted out the card problem time will tell, I'll keep you posted. If it dont work.......burn it!
Post #241986 11th Feb 2014 4:38pm
cheers for that.. Thumbs Up
Post #241987 11th Feb 2014 4:40pm
Welshdragon
You be upgrading soon then ? Whistle Cool If it dont work.......burn it!
Post #241991 11th Feb 2014 4:45pm
yep, my crappy 720p jobby will go nto the wifes car and i'll get something a bit better..
Post #242003 11th Feb 2014 5:41pm
Prop
Just double checked my memory card and its definitely class 10 and has worked flawlessly from 1st Nov 2013. But as you said it does state to avoid class 10. Its what I had sitting around so used it and its never given me any cause to worry. The dashcam has recorded in excess of 135 hours so far and I have it set to record 3minute clips.
Firmware version is as I bought it 20130913. Never had any need to update it so doubt I ever will.
Post #242007 11th Feb 2014 6:05pm
Welshdragon
Top job Prop Thumbs Up
I will see if this class 6 does the job, if not I will try a class 10 32gb card, seem very strange when you look at some forums/reports on this cam some are ok with class 10 and others not! I did a lot of searching which was the best cards to buy and ones to avoid as well !
These links might be of use to others here. ( number 1 and 3 helped ) Thumbs Up
1. http://dashcamtalk.com/mini-0801/
2. http://www.networkcameracritic.com/?p=2069
3. http://www.simonfoster.co.uk/mini-0801-dash-camera-part-2/
4. http://www.simonfoster.co.uk/mini-0801-dash-camera-part-3/ If it dont work.......burn it!
Post #242019 11th Feb 2014 6:58pm
