Home > Technical (L322) > vibration at speed
Welshdragon
vibration at speed
The FF has always had since I bought it a slight vibration when traveling between 55 and 65 mph, some times it's worse than other days, nothing really terrible but it is felt through the front footwells.
There is nothing at 30mph and nothing at 70mph, well nothing can be felt.
Would I be right in thinking prop shafts ?
I have had this kind of thing on my 90 and 110 which where prop related, balance weight had come off, hence me thinking the prop route.
Anyone had simmular experiance ? If it dont work.......burn it!
Post #235827 19th Jan 2014 11:47am
mike & the mechanics
United Kingdom 2007 Range Rover Vogue SE TDV8 Galway Green
Have you checked wheel balancing? Mine is on 20" & I had the same took them twice to the place that fitted my tyres to no avail so started to think problem then a TPS valve failed & had to make an emergency call Sturgess landrover at Leicester who re-balanced my wheels & guess what? now perfect. makes you wonder on these big wheels can a lot of independents do them properly!! Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #235829 19th Jan 2014 11:53am
Could be a million things from a bush to a buckled wheel to a propshaft unbalance or doughnut issue... There is no common fault I can think of... But many it could be Neutral
Post #235831 19th Jan 2014 11:55am
Welshdragon
Ok first off then to get wheels checked out, as i'm on 20" wheels as well, but there is no steering wabble at all.
I'll crawl under her tomorrow and see the props if theres any kind of play in them and the doughnut ( I thought V8's had u j's on the props both ends? !)
I know its a bit of ' stab in the dark ' kind of question but thinking I should get this sorted out before the warranty runs out in a few months time Sad If it dont work.......burn it!
Post #235835 19th Jan 2014 12:16pm
There's a doughnut in the rear prop on the SC in front of me sir... Whistle
Post #235838 19th Jan 2014 12:24pm
Welshdragon
lol, just checked mine....there IS a doughnut on them! Thumbs Up If it dont work.......burn it!
Post #235841 19th Jan 2014 12:35pm
Not just looking at it humm... Laughing
Post #235847 19th Jan 2014 12:52pm
Welshdragon
Rolling with laughter Rolling with laughter Rolling with laughter If it dont work.......burn it!
Post #235855 19th Jan 2014 1:25pm
Thumbs Up Bow down Thumbs Up
Post #235862 19th Jan 2014 1:57pm
Welshdragon
Up date - I had the wheels all balanced and swapped the fronts to rears, all seams well at the moment at 50/60 mph Thumbs Up
@ Craig, there are 2 doughnuts on the FF, rear diff end and front gearbox end.....oh and one the plate on the table Rolling with laughter Rolling with laughter Rolling with laughter If it dont work.......burn it!
Post #236914 24th Jan 2014 8:24pm
Simples Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #236918 24th Jan 2014 8:30pm
And the one looking for it Laughing Bow down Thumbs Up
Post #236934 24th Jan 2014 9:31pm
Welshdragon
Rolling with laughter Rolling with laughter Rolling with laughter Funny F Censored r Laughing If it dont work.......burn it!
Post #236948 24th Jan 2014 9:49pm
Googsy
Was gonna suggest not sticking your head out the window when driving but as your sorted it's not relevant now Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #236951 24th Jan 2014 9:53pm
Welshdragon
Laughing Laughing Laughing , I'm sure my head was inside the RR.....not sure the brain was with me.....then I'm not sure I got one.....driving these Green ovals for most of my life and been laid on my back repairing them, you sure got to be mad some what Rolling with laughter
Up date again, while out on a decent run today I can be sure the vibration is no longer there, spent most of the journey at 50/60 mph, I suppose I'd better pay the tyre fitter some beer money for a top job Thumbs Up If it dont work.......burn it!
Post #237141 25th Jan 2014 8:23pm
