Home > Technical (L322) > vibration at speed |
mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178 |
Have you checked wheel balancing? Mine is on 20" & I had the same took them twice to the place that fitted my tyres to no avail so started to think problem then a TPS valve failed & had to make an emergency call Sturgess landrover at Leicester who re-balanced my wheels & guess what? now perfect. makes you wonder on these big wheels can a lot of independents do them properly!! Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
19th Jan 2014 11:53am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Could be a million things from a bush to a buckled wheel to a propshaft unbalance or doughnut issue... There is no common fault I can think of... But many it could be |
19th Jan 2014 11:55am |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
Ok first off then to get wheels checked out, as i'm on 20" wheels as well, but there is no steering wabble at all.
19th Jan 2014 12:16pm |
There's a doughnut in the rear prop on the SC in front of me sir... |
19th Jan 2014 12:24pm |
19th Jan 2014 12:35pm |
Not just looking at it humm... |
19th Jan 2014 12:52pm |
If it dont work.......burn it!
19th Jan 2014 1:25pm |
19th Jan 2014 1:57pm |
Up date - I had the wheels all balanced and swapped the fronts to rears, all seams well at the moment at 50/60 mph
24th Jan 2014 8:24pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8626 |
Simples There is nothing that can't be fixed with a hammer😜😜
24th Jan 2014 8:30pm |
And the one looking for it |
24th Jan 2014 9:31pm |
Funny F r If it dont work.......burn it!
24th Jan 2014 9:49pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Was gonna suggest not sticking your head out the window when driving but as your sorted it's not relevant now Present :2008 TDV8 HSE
24th Jan 2014 9:53pm |
, I'm sure my head was inside the RR.....not sure the brain was with me.....then I'm not sure I got one.....driving these Green ovals for most of my life and been laid on my back repairing them, you sure got to be mad some what
25th Jan 2014 8:23pm |
