![]() | Home > Maintenance & Mods (L322) > any one done this mod? |
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 965 ![]() ![]() ![]() |
hi everyone
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7878 ![]() ![]() ![]() |
That looks like just the later Land Rover / BMW part. I'm pretty sure its a BMW part anyways..........
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35529 ![]() ![]() |
its not actually a modification Andy but a replacement part which ducky Dan does for around £35..
does it have the desired effect and help the battery......? |
I understand the original one will drain the battery if it fails. Should be fine otherwise.
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Best buy a genuine part from Dan |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
I bought two for £30 off the bay, 1st one still going strong (but I am on my 3rd one in 5 years!)
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
did you know there are two FSR fitted to the car |
There certainly is. |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1668 ![]() ![]() |
HOW MUCH? |
does anyone know how you change the one that controls the rear one? |
There is a YouTube video I think andy |
Really craig for the rear one?.... i will have a butchers |
you will need to lift the center consol or remove it, you will see the fan motor at the bottom bolted down, bolts are on both sides along with a multi plug, at the front of the motor there is a clip on the plastic work, this is a |
