Home > Maintenance & Mods (L322) > any one done this mod? |
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 952 |
hi everyone
16th Dec 2013 12:07pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7815 |
That looks like just the later Land Rover / BMW part. I'm pretty sure its a BMW part anyways..........
16th Dec 2013 12:13pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35368 |
its not actually a modification Andy but a replacement part which ducky Dan does for around £35..
16th Dec 2013 12:14pm |
does it have the desired effect and help the battery......? |
16th Dec 2013 2:52pm |
I understand the original one will drain the battery if it fails. Should be fine otherwise.
16th Dec 2013 3:02pm |
Best buy a genuine part from Dan |
16th Dec 2013 3:03pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
I bought two for £30 off the bay, 1st one still going strong (but I am on my 3rd one in 5 years!)
16th Dec 2013 5:43pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
did you know there are two FSR fitted to the car V8 facelift Range Rover Autobiography 22" wheels.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
There certainly is. |
16th Dec 2013 5:49pm |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
HOW MUCH? |
17th Dec 2013 9:45am |
does anyone know how you change the one that controls the rear one? |
18th Dec 2013 8:51am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
There is a YouTube video I think andy |
18th Dec 2013 8:54am |
Really craig for the rear one?.... i will have a butchers
18th Dec 2013 1:54pm |
you will need to lift the center consol or remove it, you will see the fan motor at the bottom bolted down, bolts are on both sides along with a multi plug, at the front of the motor there is a clip on the plastic work, this is a to get to and you will find that it snaps...the FSR is mounted in the side V8 facelift Range Rover Autobiography 22" wheels.
18th Dec 2013 7:30pm |
