Home > Maintenance & Mods (L322) > any one done this mod?
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
hi everyone
i have seen that powerfuluk do a mod to replace the resistor that controls the front fan unit for the heater etc as the original part is supposed to drain the battery..... 2 q's....
is this correct? & has anyone done it?
here's the link....
http://www.powerfuluk.com/products/range-r...istor.html
andy
Post #229515 16th Dec 2013 12:07pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Yup, quite common, search for FSR or final stage resistor, got my garage to replace mine a couple of years back.
Post #229517 16th Dec 2013 12:12pm
mjdronfield
That looks like just the later Land Rover / BMW part. I'm pretty sure its a BMW part anyways..........
Is it not cheaper from the main dealer ?
I'd double check before ordering.
Not sure of the equiv BMW part number, but when a mate of mine changed his, it was a BMW unit he put in.
I believe the cooling "prongs" are slightly longer, which can make it more of a tight squeeze to change.
Looks the right part to me. Just not sure if its the right price... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #229518 16th Dec 2013 12:13pm
its not actually a modification Andy but a replacement part which ducky Dan does for around £35..
loads on the forum re this , search 'fsr' or 'final stage resister' ... - .- -.
Post #229519 16th Dec 2013 12:14pm
andyleeds
does it have the desired effect and help the battery......?
Post #229567 16th Dec 2013 2:52pm
mjdronfield
I understand the original one will drain the battery if it fails. Should be fine otherwise.
The original unit is prone to failure though, but I'd still only change it if its causing you an issue. It could still be good.
Fault symptoms appear to be fan only working at full speed and coming on and off, up and down on its own. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #229569 16th Dec 2013 3:02pm
Best buy a genuine part from Dan
Post #229571 16th Dec 2013 3:03pm
I bought two for £30 off the bay, 1st one still going strong (but I am on my 3rd one in 5 years!)
See my howto here:
http://metricrat.co.uk/replacing-the-final...kiii-2002/
No point replacing it unless you have no fans, fans all the time or severe battery drain .
Post #229604 16th Dec 2013 5:43pm
daveo
did you know there are two FSR fitted to the car Shocked V8 facelift Range Rover Autobiography 22" wheels.
Post #229605 16th Dec 2013 5:43pm
There certainly is. Thumbs Up
Post #229609 16th Dec 2013 5:49pm
Martin
Site Admin
HOW MUCH? Shocked
Post #229736 17th Dec 2013 9:45am
andyleeds
does anyone know how you change the one that controls the rear one?
Post #229975 18th Dec 2013 8:51am
There is a YouTube video I think andy Thumbs Up
Post #229978 18th Dec 2013 8:54am
andyleeds
Really craig for the rear one?.... i will have a butchers Smile
...... did you ever get a chance to have a look to see if you had those sat nav ends in your Aladins cave in Piano Black.....
Post #230008 18th Dec 2013 1:54pm
daveo
you will need to lift the center consol or remove it, you will see the fan motor at the bottom bolted down, bolts are on both sides along with a multi plug, at the front of the motor there is a clip on the plastic work, this is a Censored to get to and you will find that it snaps...the FSR is mounted in the side V8 facelift Range Rover Autobiography 22" wheels.
Post #230056 18th Dec 2013 7:30pm
