![]() | Home > General (L405) > Heated Front windscreen |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
You will need to fill in your car profile (that means we can see what model your FF is) essential when your asking questions about your specs sir |
Saintboggart Member Since: 17 Oct 2013 Location: Bucks Posts: 8 ![]() ![]() ![]() |
I will sort that out, in the meantime 3.0 TDV6 vogue SE |
5.0 Member Since: 25 Feb 2012 Location: Surrey Posts: 718 ![]() ![]() |
Has your car got the heat reflective windscreen? On the L322 you could not have a heated screen if you had the heat reflective option. |
fairwx Member Since: 10 Nov 2011 Location: bristol Posts: 124 ![]() ![]() |
If it is an L405 Vogue SE TDV6 then it should have a heated front screen, of which the button is located below the MAX defrost button on the left hand side.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7969 ![]() ![]() ![]() |
UK supplied car ? |
Yes it is a uk supplied car |
NormanP Member Since: 15 Mar 2013 Location: Oxford Posts: 136 ![]() ![]() ![]() |
As far as I can tell, all models UK should have all three buttons/functions. Mine (Vogue) certainly does (and it has the Solar glass as an option but that shouldn't make any difference to the heated options). First frost here this morning and it certainly clears it quickly... I'd contact your supplying dealer and query this with them. Norman
Willo98 Member Since: 20 Nov 2013 Location: Reading Posts: 14 ![]() ![]() ![]() |
Have you got the heating elements in the front screen? If you look closely you should be able to see hundreds of very fine heating elements running from top to bottom. |
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 ![]() ![]() ![]() |
PDI - Notice to dealers
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2587 ![]() ![]() |
You have to wonder about letting people see bulletins like that on TOPIX. Presumably HSE bits were fitted by mistake. |
Turns out they forgot to install switch at the factory all sorted now switch installed |
Really! Wow, thought those days were gone... ![]() ![]() |
