Home > General (L405) > Heated Front windscreen |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 |
You will need to fill in your car profile (that means we can see what model your FF is) essential when your asking questions about your specs sir |
13th Nov 2013 11:56pm |
Saintboggart Member Since: 17 Oct 2013 Location: Bucks Posts: 8 |
I will sort that out, in the meantime 3.0 TDV6 vogue SE |
14th Nov 2013 11:32pm |
5.0 Member Since: 25 Feb 2012 Location: Surrey Posts: 718 |
Has your car got the heat reflective windscreen? On the L322 you could not have a heated screen if you had the heat reflective option. |
15th Nov 2013 1:04pm |
fairwx Member Since: 10 Nov 2011 Location: bristol Posts: 124 |
If it is an L405 Vogue SE TDV6 then it should have a heated front screen, of which the button is located below the MAX defrost button on the left hand side.
15th Nov 2013 3:26pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7969 |
UK supplied car ? |
15th Nov 2013 8:48pm |
Yes it is a uk supplied car |
16th Nov 2013 8:12pm |
NormanP Member Since: 15 Mar 2013 Location: Oxford Posts: 136 |
As far as I can tell, all models UK should have all three buttons/functions. Mine (Vogue) certainly does (and it has the Solar glass as an option but that shouldn't make any difference to the heated options). First frost here this morning and it certainly clears it quickly... I'd contact your supplying dealer and query this with them. Norman
19th Nov 2013 11:27am |
Willo98 Member Since: 20 Nov 2013 Location: Reading Posts: 14 |
Have you got the heating elements in the front screen? If you look closely you should be able to see hundreds of very fine heating elements running from top to bottom. |
22nd Nov 2013 2:12pm |
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 |
PDI - Notice to dealers
27th Nov 2013 7:17am |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2587 |
You have to wonder about letting people see bulletins like that on TOPIX. Presumably HSE bits were fitted by mistake. |
27th Nov 2013 10:09am |
Turns out they forgot to install switch at the factory all sorted now switch installed |
13th Dec 2013 11:45pm |
Not Far to many gone... |
18th Jan 2014 4:58am |
Really! Wow, thought those days were gone... |
18th Jan 2014 5:12am |
