Home > Technical (L322) > can anyone help please. message centre problem
Page 2 of 3 <123>
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Jackofq300 wrote:
great thank you lads. when i turn the camera alert on it changes back to english. and says "check front side light" but the lights are fine. ive got a 2010 front convertion so the lights are led and working fine. ive had the car about 3 months now and this problem only ocurred a couple of days ago. any ideas how to fix this little bug peeps?? the diagnostic tool does not switch it off worst luck.
As Stan said, with NAvcoder you can switch off the monitoring of the bulbs, but I suspect the root cause is that the LED canbus resistor has failed and therefore is triggering a fault message. Try a new set of bulbs.
Glad my Portuguese translation was right!
Post #220443 3rd Nov 2013 8:27am
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
Sorry for being late, but it is French indeed, verifier feu (feux) position avant, check front light(s) and you did find the solution already, so this reply is completely overdone. Sorry Embarassed
Post #220448 3rd Nov 2013 9:16am
Jackofq300
United Kingdom 2002 Range Rover HSE 4.4 V8 Zambezi Silver
ok thank you stan. i bet them led bulbs are expensive. i might just griin n bear it for now. would my id tool be able to turn off hot and cold monitoring? never seen that in the menu..
Post #220719 4th Nov 2013 5:25pm
Simes
The bulbs cheap enough - and the LEDs are only about £3 each. If you go with the LEDs you need to use iid or nav - coder to switch off the cold monitoring anyway, otherwise they flash like a disco every 40 seconds.
Post #220721 4th Nov 2013 5:28pm
^ what Simon said Paul.. ... - .- -.
Post #220722 4th Nov 2013 5:35pm
Jackofq300
ok thanks simon and thanks again stan. just one more thing. where would i get a nav coder or iid from. im thick as you have probably worked out but i have never heard of them.
Post #220730 4th Nov 2013 5:59pm
britpart are the main distributor for the iidtool and if you contact them they will supply a list of dealers, or you could try ebay...
not sure re the nav-coder , maybe ebay? .. ... - .- -.
Post #220734 4th Nov 2013 6:03pm
Jackofq300
i have a britpart id tool. can it be done with that? or does it have to be the nav coder
Post #220737 4th Nov 2013 6:07pm
Jackofq300
Post #220738 4th Nov 2013 6:08pm
the GAP iidtool should be able to do it, have a look here and enter your details in the drop down menu,
http://www.gap-diagnostic.com/products/iidtool.html ... - .- -.
Post #220739 4th Nov 2013 6:09pm
edit, it appears you can...[last item]
Post #220740 4th Nov 2013 6:12pm
Jackofq300
ok will do. thank you
Post #220743 4th Nov 2013 6:27pm
Jackofq300
Post #220747 4th Nov 2013 6:47pm
thats ok mate, you dont have to thank me twice.. Laughing ... - .- -.
Post #220753 4th Nov 2013 7:44pm
Jackofq300
ok ok lol.just enjoying the great feedback on this forum. and cheers for the id tool thread. ive just lowered the RR by 55mm.
Post #220816 4th Nov 2013 10:47pm
Page 2 of 3 <123>
