Home > Technical (L322) > can anyone help please. message centre problem |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
As Stan said, with NAvcoder you can switch off the monitoring of the bulbs, but I suspect the root cause is that the LED canbus resistor has failed and therefore is triggering a fault message. Try a new set of bulbs. Glad my Portuguese translation was right! |
3rd Nov 2013 8:27am |
Jackofq300 Member Since: 11 Aug 2013 Location: Dart ford Posts: 45 |
ok thank you stan. i bet them led bulbs are expensive. i might just griin n bear it for now. would my id tool be able to turn off hot and cold monitoring? never seen that in the menu.. |
4th Nov 2013 5:25pm |
The bulbs cheap enough - and the LEDs are only about £3 each. If you go with the LEDs you need to use iid or nav - coder to switch off the cold monitoring anyway, otherwise they flash like a disco every 40 seconds. |
4th Nov 2013 5:28pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35264 |
^ what Simon said Paul.. ... - .- -.
4th Nov 2013 5:35pm |
ok thanks simon and thanks again stan. just one more thing. where would i get a nav coder or iid from. im thick as you have probably worked out but i have never heard of them. |
4th Nov 2013 5:59pm |
britpart are the main distributor for the iidtool and if you contact them they will supply a list of dealers, or you could try ebay...
4th Nov 2013 6:03pm |
i have a britpart id tool. can it be done with that? or does it have to be the nav coder |
4th Nov 2013 6:07pm |
4th Nov 2013 6:08pm |
the GAP iidtool should be able to do it, have a look here and enter your details in the drop down menu,
4th Nov 2013 6:09pm |
edit, it appears you can...[last item]
4th Nov 2013 6:12pm |
ok will do. thank you |
4th Nov 2013 6:27pm |
4th Nov 2013 6:47pm |
thats ok mate, you dont have to thank me twice.. ... - .- -.
4th Nov 2013 7:44pm |
ok ok lol.just enjoying the great feedback on this forum. and cheers for the id tool thread. ive just lowered the RR by 55mm. |
4th Nov 2013 10:47pm |
