Home > Technical (L322) > can anyone help please. message centre problem
Page 1 of 3 123>
Jackofq300
United Kingdom 2002 Range Rover HSE 4.4 V8 Zambezi Silver
does anybody know what 'verif feu posit av' means?? it keeps showing up on my 2002 l322 RR. ITS DRIVING ME MAD.
Post #220226 1st Nov 2013 7:27pm
looks french..can you change your language to english. ... - .- -.
Post #220227 1st Nov 2013 7:36pm
Jackofq300
hi stan. yeah i was thinking that. ive a diagnostic tool and seems to work fine and shows no faults. the car is uk spec. any idea to change language. regard. jacko.
Post #220233 1st Nov 2013 7:46pm
should be in the menu somewhere..you havnt put a new nav disc in by any chance.. ... - .- -.
Post #220235 1st Nov 2013 7:49pm
Jackofq300
ok thanks i will check. it does have the upgrade tv plus 2010 satnav. the cars very new to me.
Post #220237 1st Nov 2013 7:56pm
there are issues with aftermarket sat nav discs with speed cams on them cause the language to be defaulted to french..
this thread helps to explain the problem [it does go off topic a bit though] ... - .- -.
Post #220238 1st Nov 2013 8:01pm
Jackofq300
could of hit the nail right on the head there. my wife has been mucking around with the head unit. i wil check it out. thank you. top man stan..
Post #220240 1st Nov 2013 8:07pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Is it French or Portuguese?
Google translate, whilst not being very helpful, thinks its Portuguese!
I think it's pigeon French and is saying check position light at the rear of the car - so possible a blown sidelight bulb at the back?
Might be pigeon Portuguese actually and be a front light - investigation implies that AV could be a Portuguese abbreviation for 'before'...
Post #220320 2nd Nov 2013 12:23pm
hopefully if Paul can default the language to english then the error will become more clearer.. ... - .- -.
Post #220342 2nd Nov 2013 2:36pm
Jackofq300
thanks again chaps but i dont think it would be the lights as they are the 2010 led type. i tryed to change language lastnight but had no luck. not having a manual for the head unit doesnt help either. i will keep trying
Post #220348 2nd Nov 2013 3:58pm
Jackofq300
oh stan i dont think you posted that thread. i could not see it on your reply
Post #220351 2nd Nov 2013 4:05pm
'ere you go.
Post #220364 2nd Nov 2013 5:02pm
Embarassed
thanks David.. Thumbs Up ... - .- -.
Post #220365 2nd Nov 2013 5:07pm
Jackofq300
great thank you lads. when i turn the camera alert on it changes back to english. and says "check front side light" but the lights are fine. ive got a 2010 front convertion so the lights are led and working fine. ive had the car about 3 months now and this problem only ocurred a couple of days ago. any ideas how to fix this little bug peeps?? the diagnostic tool does not switch it off worst luck.
Post #220374 2nd Nov 2013 5:55pm
probably one of the bulbs are now causing a canbus error..
solution is to buy some new error free bulbs or get a diagnostic tool to switch off the hot and cold monitoring ,, ... - .- -.
Post #220385 2nd Nov 2013 6:41pm
Page 1 of 3 123>
