![]() | Home > Maintenance & Mods (L322) > 2006–2009 Headlights & External LED/'Xenon' bulb upgrade |
*** Any person following this thread and who changes bulbs/ upgrades anything based on anything posted does so at own risk and knowing that it is your own responsibility to first be satisfied that any changes you make are safe, will not cause damage, are fit for purpose and are otherwise compliant with road vehicle regulations and the law applicable to the place(s) where the vehicle will be used ***
Advanced Factors Site Sponsor Member Since: 31 May 2013 Location: Southampton Posts: 198 ![]() ![]() |
SMD's are a product range that we are currently growing our stock range of, most so far are panels for interior lights. We have a CANBUS 501 for side lamps but not yet tried it in a FF for size. (it's a big lad!)
Thanks Steve. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35634 ![]() ![]() |
i've made subtle changes to my front lights,
Cheers Stan |
Found advert for 4-5k CAN-BUS LED Sidelight bulbs made by BLESK 501 / W5W:
which 'white' are you going for Rayn?
certainly 5000k will be the nearest to white but do consider 6000k as this colour temperature is fairly close as well and easier to find.. ... - .- -.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6766 ![]() ![]() ![]() |
6000k is perceptively more blue than the 5000k if you look at them side by side.
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 ![]() ![]() |
I put a pair of these in my car to replace the standard incandescent side light bulbs. I would say they are slightly whiter than the standard HID's which I believe are 4300k, so would rate these as around 5000k or just over.
those bulbs look the business ..5630 smds are the better ones that are available.. ... - .- -.
@ Prop - As Stan says, those sidelight bulbs sound like they're just the job... take it they are white without any obvious hint of aftermarket blue? |
I would consider them as white, but this is open to interpretation. They are definately more blue than the standard HID's, but they are certainly not tinted blue, more of a crisp white.
Stan you are indeed correct, the SMD 5630 led is approx twice as bright as its predecessor the SMD 5050.
