Home > Maintenance & Mods (L322) > 2006–2009 Headlights & External LED/'Xenon' bulb upgrade
Page 9 of 9 <123456789
pld118
The seller has since said that for this car they recc this bulb?
http://www.ebay.co.uk/itm/1157-BAY15d-P21-...20cbc9d55e
Post #231048 23rd Dec 2013 4:56pm
first of all its white not red, secondly i cant figure how it can be dual wattage [21w and 5w].. ... - .- -.
Post #231051 23rd Dec 2013 4:59pm
pld118
Totally confused Stan. Have sent the seller that extract you helpfully offered from the manual. Response pending. Thanks
Post #231054 23rd Dec 2013 5:15pm
Prop
Stan, just getting back to the 50watt Cree bulbs.
You are indeed correct in what you say about the Cree leds current. Where it gets confusing is that this is each individual Cree led. So lets take the 400ma current. If we use the wattage formula then we can multiply 12volts times 0.4 amps or 400mA which equates to 4.8watts.
The problem with the 50 watt Cree bulbs you have is that it contains 10 of these Cree leds. Each one will consume a maximum of 400ma so if you times that by 10 it means the bulb has the potential to consume 4.0 amps or 4000mA. While the wiring will be fine with this my concern is more about the strain on the rest of the electronics to drive the indicators and whether or not this could cause long term damage I do not know.
If we take the standard 21watt bulb this consumes a maximum of 1.75amps or 1750mA. It might be that the electronics cope with the higher current draw of the 50watt Cree 4.0 amps no problem, but I would not like to say, and I certainly do not know enough about the overhead capability of the RR indicator circuitry etc.
Post #231056 23rd Dec 2013 5:18pm
ahh man, i thought i won that fight.... Laughing
those calculations are a bit over my head Prop and i bow to your knowledge on this subject..
my mind goes to the red brake light that must be a fair wattage due to the brightness and i surmise your honour that if that can take the amps then surely the cree bulbs should be ok?...and because the indicators arnt used in a constant manor like tail/headlights etc then the wiring [if indeed put under a strain] wont suffer ... ... - .- -.
Post #231062 23rd Dec 2013 5:32pm
Prop
Stan, just wanted to keep you informed so you know the correct specs and can better calculate your risks, I am confident using just 2 of these bulbs at the rear should be ok. But running front and rear 50watt would be much more risky. And with all the conflicting info supplied its better to know for sure, I learn't a long time ago to take any specs given with eBay stuff with a pinch of salt.
The tail light bulb you mention is to my calculations about 6.5watts total power consumption as each 5050smd led is approx 0.24watts and when multiplied by the amount of leds, 27 equals 6.48watts. The 5050 led uses only a fraction of the power of a Cree led but is also no were near as bright. So even using 27 5050 leds I doubt that you will see the quoted 486 lumens output.
The 5630SMD led is a much better brighter led than the 5050 so I would recommend looking for bulbs that utilize multiple 5630 leds rather than 5050leds.
Post #231076 23rd Dec 2013 6:36pm
i only suggested the rear brake lights as a comparison because of their brightness but how do you know they are 5050's?
i think the whole indicator circuit/wiring is pretty robust because, as said before, you can charge the battery via the side indicator wiring but i wouldnt put any crees in the front..the main reason putting them in the rears was to have a brighter more defined light against the bright brake light.. ... - .- -.
Post #231080 23rd Dec 2013 6:48pm
Prop
The eBay link that PLD118 gave to the bulbs in question states:
1. Base: 1157 BAY15D P21/5W
2. Light Chip: Super bright 5050 SMD(3 Chips)
3. LED Quantity:27 pc
4. Brightness Efficiency: 486 LM
5. Operating Voltage: 12V
6. Power Consumption: 5.46W
[/u]
Post #231095 23rd Dec 2013 8:05pm
a mis-constrution here Prop, i was referring the the OE led brake light on the FF... ... - .- -.
Post #231099 23rd Dec 2013 8:08pm
pld118
Rear light unit red Tail/ Fog light LED
Ordered 4 of these for £27.50 delivered.
Upper bulb – Is for the tail lamp/ twin filament
Lower bulb – Tail/ rear fog
4 x 1157 BAY15d P21/5W CANBUS SMD LED Stop/Tail bulbs RED
http://www.ebay.co.uk/itm/1157-BAY15d-P21-...4572573901
Post #231808 29th Dec 2013 8:57am
i dont think anyone has replaced the OE bulbs with leds so this will be interesting ..dont forget the pics and your opinion on these Ryan. Thumbs Up ... - .- -.
Post #231820 29th Dec 2013 10:34am
pld118
Embarassed
Post #231834 29th Dec 2013 11:35am
Laughing ... - .- -.
Post #231858 29th Dec 2013 2:05pm
pld118
Handle LED bulbs with care
I experienced initial minor problems fitting and/or removing aftermarket LED cornering bulbs and rear tail/ fog bulbs which caused some bulbs to break. This was in part due to the dry joints that can prevail when inserting aftermarket LED bulbs, partly it was due to bayonet pin position (on the rear tail/fog bulbs) and in part it was due to my fitting technique... gently does it... and I'm satisfied that these bulbs are of good quality and fit for purpose. Fortunately, the supplier of both bulbs is reputable and very customer focused, promptly supplying replacement bulbs FOC and without quibble.
** Cornering LED bulbs from hq_auto_lighting_uk on eBay. Paid £25/ pair incl del –
H8 PGJ19-1 Xenon WHITE 29W HIGH POWER CREE LED
http://www.ebay.co.uk/itm/310670163821?ssP...5091237216
Cornering bulbs - These bulbs have a two piece plastic housing that is glued together and due to the dry joints, on inserting the bulbs, hand pressure can cause the smaller of the housing pieces to break off. The bulb will still work regardless and you can compensate/ strengthen pieces by applying insulating tape before fitting. I was supplied with a replacement bulb and fitted it with no issues. These bulbs look very good on the car and they compliment the OE xenon headlights and the aftermarket LED sidelight bulbs I have fitted. They do not appear to throw out as much light as the OE cornering bulbs; however, they do work and make the car appear more visible from distance. They look right on the car and are not too bright *********************
** Tail/ Fog LED bulbs from hq_auto_lighting_uk on eBay paid £27.50 for 4 incl del –
4 x 1157 BAY15d P21/5W CANBUS SMD LED Stop/Tail bulbs RED:
The lower of the bayonet pins on these Tail/Fog LED bulbs need to be filed down in order that the bulb will fit the L322 bulb housing within in the rear light unit. Otherwise you will need to use so much force to insert the bulb and to remove the bulb that it will break the bulb. CTC and Stan of the forum suggested the pin filing method and it takes seconds to do, the bulbs thereafter fitting and removing perfectly well and without compromise to performance. The below links comprehensively cover my own and Stan's experiences of researching and fitting LED rear/ tail fog lamp bulbs which, a number of forum members first queried the need for/ feasibility of. However, the results achieved (pictured below) now seem well received by a number of forum members and from my own perspective, is one of the most pleasing, easy and cost effective upgrades that results in crisp, OE modern, improved rear visibility on the L322:
http://www.fullfatrr.com/forum/post234807.html#234807
http://www.fullfatrr.com/forum/topic23234.html
Still image -Supercharged rear tail/ fog aftermarket LED bulbs close up in the dark:
Post #233451 7th Jan 2014 6:02pm
