Home > Maintenance & Mods (L322) > Brake Disc Change
Page 4 of 5 <12345>
Vogue
delamo that was exactly my thoughts when I saw the pics. I had my brakes done 6 weeks ago and they most certainly didn't look like that, even prior to bedding in. Dan no way are those bedded, either the discs are out of true, surface uneven or the pads are goosed.
The discs should have an even bright finish throughout their whole diameter and circumference. Did you refit the old pads by any chance??
Post #21300 29th Jun 2010 9:39pm
dan_uk_1984
I took that pic after a 2 mile drive back from the garage, so they weren't bedded in yet. However, now the wear band is solid and uniform. Thanks tho! Thumbs Up
D
Post #21306 29th Jun 2010 11:40pm
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
Very Happy Thats good to know Dan - had an idea you would know what was right, was just concerned, thats all Thumbs Up
(Nice touch with the drilled / vented discs by the way - very snazzy!)
Post #21311 30th Jun 2010 12:34am
dan_uk_1984
Good to know you all have my safety in mind!
I did re-use the pads, so I was expecting poor performance for a while and am hoping that's the answer to my shimmy. Will wait another few hundred miles and get the wheels balanced.
Post #21318 30th Jun 2010 7:47am
Vogue
a friend did that and re-used pads that were only a few hundred miles old - he unfortunately ended up with new warped discs.
Post #21324 30th Jun 2010 9:20am
dan_uk_1984
How/Why?
Post #21325 30th Jun 2010 9:40am
Vogue
a mechanics opinion was that as the pads were only making partial contact over the whole of the disc, this led to increased friction on a smaller contact area and therefore significantly more heat generation than was design intended - which resulted in his warped discs.
If you think about it, it is logical that if the pads are only making partial contact all the braking effort is going through this reduced contact area = significantly more heat.
The warped disc symptoms were significant wobble at between 60 and 70mph only when braking - otherwise it was ok - discs only seem to wobble when braking as the pads are in contact with the disc and it travelled up through his steering wheel quite badly.
Out of balanced wheels in my experience are slightly there all the time, but get slightly more progressively worse through certain speed ranges - braking doesn't usually have an effect on out of balance wheels.
Really hope this isn't bad news Dan
Post #21326 30th Jun 2010 10:47am
dan_uk_1984
Thanks for that, makes sense. However I was very gentle with the breaking for the first 200+ miles so don't think I could have heated them beyond their tolerances. At the end of the day they were cheap discs so they could just be slightly warped already.
I've noticed the shimmy has decreased over the last few days, I was late this morning so wasn't hanging about and can't say I noticed it, but there wasn't any super high speed braking, just country lanes. I'll go home via a fast road this eve and see if I can pick up the shake again.
I think my balancing/tracking is out anyway, so I do need to get this looked at. Along with my lower ball joint on the passenger side has failed again, after about 25K of our Censored roads that fall off into the ditches and leave massive craters.
Post #21327 30th Jun 2010 10:54am
Just got back in from spending the afternoon changing my discs (no name) and pads (Mintex). My servicing guy identified worn discs last time round. The pads that came off had plenty of wear left, but it seemed a shame to put old pads onto new discs. Discs didn't look too bad - I would have run them on for another 30K but MOT looms.
Safety First
Wheels and discs just "fell off", fortunately there was evidence of copper ease on both.
The allen screw in the disc was missing on both sides, so I have to get a couple of those on order.
I was able to get the pads out without removing the guide bars, then just pulled the caliper carrier out complete with guide bars. Much easier to tackle off the caliper. Unless you have four arms and really strong fingers, don't try "not" removing the caliper carrier and try to refit the brake pads, its just not worht the effort Smile
The brake pad sensor is a fiddle to get off get back on, it seems looser now, but I'll keep an eye on it.
Had to make an emergency trip to Halfords to get the right sized allen / torx for the guide bars (7mm allen or TX45 should do it) and was surprised that the extremely tough bolts (all 4 fought me right to the end of the thread!) holding the caliper on were 5/8 and not metric.
I reused the guide bars, just gave them a good rub down with 1200 wet and dry - good as new Smile
Lots of copper ease used in the refit, I plan to have "Big Bob" around when new discs and pads are needed again!
And thanks for the tip about brake cleaner. Grabbed a can of Wynns brake cleaner, did a good job of cleaning off all the protective muck on the discs and helped with cleaning up the calipers
I also invented the Acme Brake Piston Pusher Inner from a piece of wood, a 2p piece (sorry your majesty) and some nuts and bolts and bits left over from a seat belt installation on an MG or Mini a couple of decades ago. Worked a treat. [NOTE: check you have enough room in your master cylinder reservoir, to avoid spillage and possible paint damage under the bonnet]
Road test showed similar performance to before.......
Post #21560 4th Jul 2010 5:46pm
dan_uk_1984
Great Pics Joe90, they were the pics I should have taken!
D
Post #21634 6th Jul 2010 7:52am
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Best 2p's worth I've seen for a while! Thumbs Up
Post #21663 6th Jul 2010 12:55pm
Bigbangman
United Kingdom 2006 Range Rover Vogue SE TDV8 Java Black
Brake Disc Change
Question Question Question
Hi, i also have a pajero for my sins as well as a FFRR, on the Pajero brakes you can't push the pistons straight back in as the back flow of fluid could damage the ABS, is this the same for FFRR e.g, use a hose clamp, drain some fliud, push piston back and bleed?
There again i might be completely wrong here, i'm no mechanic !!!
Cheers If its not broke now it soon will !!!
Post #21673 6th Jul 2010 1:42pm
Re: Brake Disc Change
Cheers
It's a good point Bigbangman. The Rave instructions tell you to undo the bleed nipple and push out some fluid (using tubes and bottle with fluid in it), but I have not experienced any problems with any car, with ABS, including P38A, doing it my way, and not had any warnings form the car re ABS. .
Post #21684 6th Jul 2010 8:53pm
dantheman
No problem pushing the pots back in the calipers - a wind back tool worked effortlessly for me. Probably one of the best tools I have ever bought to be honest:
http://www.amazon.co.uk/Draper-40141-18PC-...B000PJ8NLE
Post #21689 6th Jul 2010 9:05pm
Looks like I'll have to sort out a "blow mould storage carrying case with display sleeve" for my Acme Very Happy  .
Post #21691 6th Jul 2010 9:12pm
Page 4 of 5 <12345>
