Home > In Car Electronics (L322) > Bluetooth in my 02 L322 Vogue |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7823 |
Sorry, PC having a bit of a hardware failure.........got it going again.........
22nd Oct 2013 7:12pm |
You will have to proceed as if you have no phone. The unit in your car is a telephone control module (tcm) by BMW. That will not do Bluetooth. You will need to buy a BMW ulf and cable and antenna, but not microphone, as I assume that is already there.
15th Dec 2013 4:58pm |
Shandonman Member Since: 02 Dec 2013 Location: Argyll Posts: 90 |
So from what I can gather from posters, get 2nd hand BMW ulf from bay of e. Anything I should know ? how about the lead and antenna, the same place ? Then rewire the connector like you say and I'm sorted. |
15th Dec 2013 11:16pm |
Have a search for BMW ulf and you will find loads of info. The bay of e seems to be the best bet. The newer the version the better is the case. 13 versions were done over the years, shown by a different part number. I have a 6 the generation unit which also does voice control, ant it works with my iPhone 5 fine.
16th Dec 2013 8:01am |
So now have in possession, 1 2nd hand ULF fourth gen from eBay, antenna from same, the Audi connector block as discussed and a wee push button for pairing. The mic is present in the hatch in front of the sunroof I was too hasty ordering the cable and didn't realise that it's coming from China so another couple of weeks before I can install.
27th Dec 2013 11:44pm |
The phone just sees the car as a Bluetooth headset. I don't have a separate headset to try, but if you do, it should behave the same.
28th Dec 2013 7:52am |
So all the parts are now here and ready to go. Stripped all the trim out of the boot but before swapping the parts, a couple of questions.
8th Jan 2014 6:50pm |
Didn't have an existing unit in mine, so don't know for sure, but I'd pop it out the way and see how you get on.
8th Jan 2014 7:03pm |
All done & working fine. A bit of a fiddle moving the pins & took a few attempts to pair. Now I need to work out how the set up works on the screen as so far I keep calling someone by mistake every time I press a button. Thanks for all the advice |
9th Jan 2014 8:43pm |
Excellent news. If you press the button on the steering wheel it calls the last number if you are not carefull. The rt button toggles between radio and telephone for the use of the forward and back buttons on the wheel.
9th Jan 2014 9:10pm |
All still working fine & lovely and clear for me and the other person on the phone. However, when the phone rings, there is no number or name of the caller displayed either on the screen or the instrument cluster. Is it the same for everyone else whose done this mod ? |
17th Jan 2014 12:24am |
WatchcamL322 Member Since: 10 Apr 2015 Location: Bath Posts: 8 |
Hi all, Has anyone seen any info on how to retire the 54 connector to add the BMW box? Looked high and low .. Thanks |
25th Apr 2015 6:11pm |
It should all be on this forum.
25th Apr 2015 6:54pm |
Or in a simpler format
25th Apr 2015 7:00pm |
