Home > In Car Electronics (L322) > Bluetooth in my 02 L322 Vogue
Page 2 of 6 <123456>
mjdronfield
Sorry, PC having a bit of a hardware failure.........got it going again.........
You must leave 32 in the ULF, (it normally would go to the pairing button in the console). Thats why I used a choccy block. Cut the wire (with fuse 22 out if you are safety conscious) and join back with a choccy block.
I cut the brown 36 wire further from the ULF down the loom - easier to get to - just trace the wire. and put a choccy block in there too - the only difference being I added a wire (any similar wire will do) so that it came out and was long enough to reach the choccy block from pin 32. I pushed the bare end into the choccy block thats on the 32 wire to simulate a button press.
A bit agricultural, but it worked.
I then put a choccy block on the free end to stop it shorting when I wasn't pairing.
About 6 months later I got a pushbutton switch from Maplin and wired that in the boot instead. Tidied the whole job up.
If that makes sense ?
Both have to always be connected to the ULF, hence the "breaking in" to the circuit. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #218129 22nd Oct 2013 7:12pm
Shandonman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Adriatic Blue
Hi,
Can you help ? I also have a 2002 and would love to add BT. I have the brick phone in the cubby box cradle. Pressing the tel button gives me a message on the screen to insert card. Without too much disassembly I can see this unit in the boot area. Is this the existing telephone unit or BT ? Do I have to get the whole unit out to tell ?
Post #229315 15th Dec 2013 4:03pm
mjdronfield
You will have to proceed as if you have no phone. The unit in your car is a telephone control module (tcm) by BMW. That will not do Bluetooth. You will need to buy a BMW ulf and cable and antenna, but not microphone, as I assume that is already there.
The 50 pin plug will also need the rewire. Don't plug it into a ulf as is, or damage will occur.
Bluetooth was never fitted to the early l322's
Hope this gives you a start...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #229336 15th Dec 2013 4:58pm
Shandonman
So from what I can gather from posters, get 2nd hand BMW ulf from bay of e. Anything I should know ? how about the lead and antenna, the same place ? Then rewire the connector like you say and I'm sorted.
Post #229449 15th Dec 2013 11:16pm
mjdronfield
Have a search for BMW ulf and you will find loads of info. The bay of e seems to be the best bet. The newer the version the better is the case. 13 versions were done over the years, shown by a different part number. I have a 6 the generation unit which also does voice control, ant it works with my iPhone 5 fine.
With the antenna, I used to suggest eBay but only a few weeks ago another member on here bought the antenna and lead brand new from a BMW dealer for the same price as used ones on the bay. Again, have a search for Bluetooth or ulf, and there are loads of info.
You may have to fabricate a pairing button. Details in other posts.
Just trying not to duplicate posts too much.
Have a read on here and let us know what you think / your plan...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #229465 16th Dec 2013 8:01am
Shandonman
So now have in possession, 1 2nd hand ULF fourth gen from eBay, antenna from same, the Audi connector block as discussed and a wee push button for pairing. The mic is present in the hatch in front of the sunroof I was too hasty ordering the cable and didn't realise that it's coming from China so another couple of weeks before I can install.
Whilst I am waiting, can anyone clarify that as I already have the Dice media bridge ( non B/T ) replacing the CD player and providing music from an iPhone via USB when the B/T module is completed will this interfere with the phone ? As at the moment when someone calls, the music interrupts and the ringtone sounds although no comms can take place, you have to unplug the phone to connect the call.
I am hoping the phone will charge &the music will play as before via Dice and the calls will be via B/T. Can anyone advise ?
Post #231670 27th Dec 2013 11:44pm
mjdronfield
The phone just sees the car as a Bluetooth headset. I don't have a separate headset to try, but if you do, it should behave the same.
I'd imagine it should work fine on the car side, as it interrupts audio and goes to telephone mode on the screen. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #231684 28th Dec 2013 7:52am
Shandonman
So all the parts are now here and ready to go. Stripped all the trim out of the boot but before swapping the parts, a couple of questions.
I've been waiting for over two weeks for the lead to arrive although I've actually got the same cable already there in the boot connecting the old tel module to what looks just like my new bluetooth module sited on top of the satnav unit Confused
Last question : the old unit has this extra cable connected to it which disappears into the d pillar. Do I just tuck this away and forget about it ?
Post #233621 8th Jan 2014 6:50pm
mjdronfield
Didn't have an existing unit in mine, so don't know for sure, but I'd pop it out the way and see how you get on.
Should be fine if you take your time.
I'd put all your new stuff in, the antenna must be for your existing phone, but could well be the same.
I'm sure someone else on here will be doing the mod at some point, so you won't be stuck with the items. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #233624 8th Jan 2014 7:03pm
Shandonman
All done & working fine. A bit of a fiddle moving the pins & took a few attempts to pair. Now I need to work out how the set up works on the screen as so far I keep calling someone by mistake every time I press a button. Thanks for all the advice
Post #233887 9th Jan 2014 8:43pm
mjdronfield
Excellent news. If you press the button on the steering wheel it calls the last number if you are not carefull. The rt button toggles between radio and telephone for the use of the forward and back buttons on the wheel.
On the screen, the number shown at the top when you are in telephone is what it will call if you don't select another number.
Usually, when I'm ending a call, if the other person disconnects before me, and I press the button on the wheel to disconnect, it calls them again......
Good to have Bluetooth in the car though. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #233893 9th Jan 2014 9:10pm
Shandonman
All still working fine & lovely and clear for me and the other person on the phone. However, when the phone rings, there is no number or name of the caller displayed either on the screen or the instrument cluster. Is it the same for everyone else whose done this mod ?
Post #235439 17th Jan 2014 12:24am
WatchcamL322
mjdronfield wrote:
Bluetooth was never available on the earlier cars, so it must have been added after. Its either using a BMW ULF module on the end of the black 54 pin connector in the boot (having been rewired) or its an aftermarket kit.
Have you got any pics, of the connector near the phone and the kit in the left hand boot compartment ?
Have a search for "ULF" on here.
Welcome to the forum !
Hi all,
Has anyone seen any info on how to retire the 54 connector to add the BMW box?
Looked high and low ..
Thanks
Post #324385 25th Apr 2015 6:11pm
mjdronfield
It should all be on this forum.
Have a search for ulf or Bluetooth.....
A chart on this thread....
http://www.fullfatrr.com/forum/topic31108.html
There is only a dozen or so wires to move if I remember right.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #324393 25th Apr 2015 6:54pm
mjdronfield
Or in a simpler format
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #324394 25th Apr 2015 7:00pm
