Home > In Car Electronics (L322) > Bluetooth in my 02 L322 Vogue
Page 3 of 6 <123456>
WatchcamL322
Amazing, thanks so much!
Been googling for days ...
Post #324399 25th Apr 2015 7:08pm
WatchcamL322
Hi all,
I have just done the rewire and plugged it all in.
I get nothing at all. No BT I can find on my phone ... No voice control and when I press the telephone button nothing happens.
Is it like this until I force a pairing mode as described in the thread?
Also there was a black cable in position 39 so I took it out. No mention of what to do in the guide with 39?
Thanks
Post #325209 30th Apr 2015 9:12pm
mjdronfield
Do you have Telephone on your screen menu ?
Is the text for it grey or white ?
You will need to put the ulf into pairing mode to get it to look for your phone.
You just needed to move the wires covered by the red text in the chart. Have you moved them to a new Audi plug you bought or have you just rewired the original plug ?
Voice control was not enabled by default on mine. I had to use navcoder.
One step at a time.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #325237 1st May 2015 5:09am
WatchcamL322
Thanks for the reply.
I followed the chart exactly and the phone was still 'greyed'.
I put the cables I removed into a taped up bundle so they were safe. ( individually so no contact)
Chart doesn't mention the black cable in 39
Also it's a bit unclear how to pair. Has anyone done it? Thanks everyone ..
Post #325749 3rd May 2015 3:03pm
mjdronfield
The text should be white, as you prob know....
Sounds like the ulf does not have power.... Have you checked the fuse ?
You only need a 12v feed and the earth to get power, plus the Ibus connection and the text will go white.
All the other connections can be done bit by bit, if you see what I mean.
Not sure about pin 39. I just moved the ones needed to a new plug I got from Audi and then connected that to the ulf. Old connector has all the other wires still in it and is not connected to anything. Sort of like you have done.
To get into pairing mode you need to short the cable in 32 to 36, but 36 will still need to be in the ulf also, so I used a chocolate block to push the wire from 32 in momentarily.
It's pointless trying to pair until you have telephone in white text.
I'll look for the proper pairing instructions. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #325752 3rd May 2015 3:14pm
WatchcamL322
Thank you .. To be clear I put a wire from one to the other while they are still in ace to short and start pairing?
Know what you mean about not being white so pointless. Will look again at that.
Black I could put back perhaps? No mention on web but it is there ... Not meant to be if chart right though?
Thanks also for tip on voice control . Will be patient Smile
Also will look into the fuse situation ..
Edit - a problem ... I have no way of knowing which is 32 now. I took it out ... Disaster?!
Post #325756 3rd May 2015 3:28pm
mjdronfield
Ulf owners manual
http://www.fullfatrr.com/gallery/albums/us...Manual.pdf
Bit of info when I was trying to fabricate the wiring.
I now have a button in the boot....
http://www.fullfatrr.com/forum/topic9678.html?highlight=pairing 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #325757 3rd May 2015 3:29pm
WatchcamL322
Thanks for the info, will digest.
Issue though not knowing which is 32 cable now. Might have blown it?
Post #325761 3rd May 2015 3:32pm
mjdronfield
Just seen your reply....
I think the procedure is something like put pin 32 into where 36 is, with 36 still in there between ulf and earth....
Rush round to front of car, turn ignition to pos 2, rush back to rear of car and pull 32 from 36 wire. Should have all 3 flashing LEDs above the screen at the front. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #325764 3rd May 2015 3:34pm
mjdronfield
It's coming back to me now ..... Smile
Pin 32 will be red / yellow and go to the eject box ie the console in the front where the pairing button would normally go.....
......but..
You don't have a pairing button, so connecting the red / yellow wire is pointless as that just goes to between the front seats with nothing on it.
So I put some wire I had kicking around into pin 32, say 5 or 6 inches long, and pushed the bare other end into 36 to simulate the button being pressed. I then put a connector on it so it doesn't touch stuff when not in use.
So your pin 32 is local to the boot now. Nothing to do with the existing loom.....
Make any sense ?
I also saw that the brown wire in pin 36 joins up to others a bit down the loom, so I connected temporarily to there to pair as it was easier to access than the actual pin on the ulf......it was all a bit tight near the ulf connector..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #325771 3rd May 2015 3:50pm
mjdronfield
Like this ;
Sorry for the scribble Laughing
To pair, remove 32 wire from choccy block A and push in to choccy block B.
Put back in A when done to stop it touching anything when not used.
I eventually put a switch in....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #325773 3rd May 2015 3:59pm
WatchcamL322
Top man ... Thanks so much.
Will attack this tomorrow all being well. I have visitors at the moment .... Fingers crossed Smile
Really appreciate your help! Will report back ..
Post #325823 3rd May 2015 6:08pm
Bobpm45
pin 39
I know its a long time since the last post but, Can we ignore pin 39 as I have it in my connector also and its not shown on the electrical circuit diagram ! I had a similar problem on my 18 pin DSP connector where the manual shows 8 wires and I have 9 ! Bob
Post #403978 8th Sep 2016 6:27am
p38arover
Australia
Shandonman wrote:
Last question : the old unit has this extra cable connected to it which disappears into the d pillar. Do I just tuck this away and forget about it ?
I started my conversion from in-car phone to Bluetooth today because the last 2G (GSM) network (Vodafone) closes on 30th September.
I wondered about the F-type connector and cable, too. It appears to go up the D-pillar. I assume it goes to an antenna for the Siemens car phone. RAVE shows the GSM antenna up at the top left - in the tailgate spoiler A Bluetooth connection wouldn't need it. I do wonder if it could be extended to a handsfree holder for the new Bluetooth phone.
I have a couple of questions. The three mounting tabs don't line up with the existing holes. I can get around it on the top but using the forward hole and using another threaded hole just forward of the rear tab.
The bottom tab can't be used so I'm planning to put a strip of foam double-sided mounting tape on the back and towards the bottom of the ULF to hold it in place and not vibrate around on our rough roads.
However, the biggest problem is the cable from the ULF to the antenna mounted on the nav system. The orientation of the connector in the ULF means the cable out of the right-angle cable connector is aimed at the vertical black mounting panel. This means the ULF cannot be screwed back on - see below.
In the pic above, the ULF mounting face is to the right. The catch on the connector is to the left, hence the cable is directed toward the mounting face. I opened up the ULF to look but the connector cannot be rotated.
I thought about reversing it end for end so the right-angled connector goes to the antenna but it can't be fitted, again because of the right-angle. Gaaahhh!
It looks like I'll need to source a new cable from somewhere.
What did others do? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #451235 18th Sep 2017 3:48am
p38arover
Australia
Re the Audi 54-pin connector p/n 4E0972144, I just ordered one form my local VW dealer. Price in Oz is $30.80 incl GST. It should be here tomorrow. I was surprised to hear VW have plenty in stock.
I could have removed the excess pins from the old connector and put heatshrink on them but thought this is a neater way to go. I just need to ensure the old plug cannot be plugged in. I'll put a piece of heatshrink over the old plug to prevent its use. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #451236 18th Sep 2017 4:34am
