![]() | Home > Off Topic - Photos and Video > The aeroplane spotters thread |
Article on the SR-71 from the early 80's
Oooo!!
edit ;
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
Good read that, thanks. |
Ha ha, I suppose they are both about the same age...
Not twice as fast.
Mach 3+ with some unofficial bits I'm sure saying closer to 4...
The absolute max was mach 3.2 - after that the engines melted.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35557 ![]() ![]() |
i wouldnt worry about the parts, Will's probably got those in his garage... |
Ha ha I would love to even have a bolt off one Stan!!
They haven't flowen for a very long time mainly because they were a bit of a hand full and troublesome |
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 ![]() ![]() ![]() |
Satellites have set/timed orbits so if you have something mobile to hide you can move it away from the satellites prying cameras between orbits. A high altitude fast aircraft can make several fly overs to track down what you are looking for. I'm willing to bet that the yanks have something already that has taken the place of the SR-17, possibly the Aurora? Travelling around in circles again. |
This is a SR071 pilot on the leaks. Wasn't such a big issue. Re parts, there's another interview with the same guy (which I can't find) and he lists a lot of the perishable parts that would need to be supplied to get the plane back in the air. It's not just a question of raiding a museum. You're right the place could fly faster today. The constraining factor was the compressor temperature, but today they could really push that temperature quite a bit higher. |
v8rich Member Since: 28 Dec 2013 Location: Healing, Lincolnshire Posts: 67 ![]() ![]() ![]() |
New toy to work on..
