Home > Maintenance & Mods (L322) > Removing wheel centre caps
Although I've done this before I thought I'd ask if anyone has a trick way of removing the centre caps to replace them with the newer ones, without removing the wheel, and without damaging the rim by jamming a screwdriver between them?
Fanders got my lovely Range Rover centres... Big Cry
Cheers Thumbs Up Discovery 4 HSE
Post #206043 28th Aug 2013 8:24am
I use a 35mm dia suction cup and a pair of pliers. Thumbs Up
Post #206044 28th Aug 2013 8:34am
GraemeC
I dont know how to do it, but it must be possible as a couple of months ago some tea leaf managed to remove mine whilst my car was on the driveway overnight... (they got 3 of them - the nearside wheel must have been too close to the fence)
No visible damage to my wheels. Wouldnt have minded, but a new set from eBay is only about £15 (might not be LR but you'd never know) 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #206046 28th Aug 2013 8:35am
Where did you get the suction cup? I have one but its not strong enough. Discovery 4 HSE
Post #206047 28th Aug 2013 8:36am
It was in my useful pieces of junk box.
It's just a standard clear plastic sucker that happens to have a metal threaded rod sticking out the back hence the pliers.
A sucker you could tie a piece of string to would work.
Just looked I have a spare one if you need it.
Post #206051 28th Aug 2013 8:44am
use a sat nav windscreen sucker , they are normally pretty strong.. ... - .- -.
Post #206052 28th Aug 2013 8:44am
A pick in the side of the cap... Flick them out Yawn
Post #206053 28th Aug 2013 8:51am
^+1 Thumbs Up
That's what I did using a thin tool from my Leatherman. No damage whatsoever. Si. <This is my name.
Post #206056 28th Aug 2013 9:10am
Ta Fellas Thumbs Up Discovery 4 HSE
Post #206241 28th Aug 2013 9:11pm
Googsy
Or if you dont plan to use old ones put a screw into centre of them and pull off with a pliers. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #206251 28th Aug 2013 9:34pm
Little sucker that you use to remove those small GU10 light bulbs in kitchens and stuff Smile works for me Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #206260 28th Aug 2013 9:47pm
Genius Conor, never thought of that Thumbs Up Discovery 4 HSE
Post #206322 29th Aug 2013 6:58am
Jeez a two minute job with the tip of a small flat headed screwdriver 👀😜
Post #206325 29th Aug 2013 7:14am
^+1
I do it all the time as above just take care and they flip out. Thumbs Up
Post #206360 29th Aug 2013 9:20am
Googsy
Kango hammer Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #206399 29th Aug 2013 11:52am
