![]() | Home > Maintenance & Mods (L322) > Removing wheel centre caps |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Although I've done this before I thought I'd ask if anyone has a trick way of removing the centre caps to replace them with the newer ones, without removing the wheel, and without damaging the rim by jamming a screwdriver between them?
I use a 35mm dia suction cup and a pair of pliers. |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
I dont know how to do it, but it must be possible as a couple of months ago some tea leaf managed to remove mine whilst my car was on the driveway overnight... (they got 3 of them - the nearside wheel must have been too close to the fence)
Where did you get the suction cup? I have one but its not strong enough. Discovery 4 HSE
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35652 ![]() ![]() |
use a sat nav windscreen sucker , they are normally pretty strong.. ... - .- -.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
A pick in the side of the cap... Flick them out |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
^+1 |
Ta Fellas |
Or if you dont plan to use old ones put a screw into centre of them and pull off with a pliers. Present :2008 TDV8 HSE
Little sucker that you use to remove those small GU10 light bulbs in kitchens and stuff |
Genius Conor, never thought of that ![]() 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top *Gone:L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
Jeez a two minute job with the tip of a small flat headed screwdriver 👀😜 |
^+1
Kango hammer |
