Home > My Range Rover > stan's new one
Page 56 of 63 <123 ... 555657 ... 616263>
Thumbs Up Thumbs Up Thumbs Up
Post #660608 28th Mar 2023 9:39pm
a quick report on the led bulbs i fitted the other day.
very wet and dark on the way home last night and the led's performed very well...
as most know the L405 headlights beam shines fairly low and needs to be higher and these bulbs certainly illuminate the immediate road ahead, it was like daylight..
very bright on high beam as you would expect.. ... - .- -.
Post #660752 31st Mar 2023 11:02am
PLC
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Led
Hi Stan, can you post a link to the bulbs, thanks
Post #660777 31st Mar 2023 2:10pm
here you go,
https://www.ebay.co.uk/itm/195398486970
i made an offer of £34.. ... - .- -.
Post #660779 31st Mar 2023 2:15pm
evotime
Thanks Stan, set on its way Thumbs Up X5 40d
Post #662710 24th Apr 2023 2:04pm
i think you'll be pleased Paul. Wink ... - .- -.
Post #662713 24th Apr 2023 2:54pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
Are they plug-and-play or are there extra wires/removal of the ballast needed?
No dash lights or codes? Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #662714 24th Apr 2023 3:24pm
they are indeed P&P...no need to remove ballasts and no dash codes .. ... - .- -.
Post #662716 24th Apr 2023 3:42pm
Bora20
Thank you sir! Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #662718 24th Apr 2023 4:12pm
PLC
LED
I had a look at the ebay link to the listing today and was wondering about the leds on the listing drawing 90 watt each were has the bulbs fitted to the car had a 35 watt draw anyone know if this is to much of a draw above the existing bulbs
Post #663107 30th Apr 2023 11:43am
i'm not to techy on this but i wouldnt take any notice of the wattage claims by the seller..
led's draw a lot less amps than xenon bulbs and they are rated in lumens and not watts..
hopefully someone who knows re leds/xenons will come along and educate us.. ... - .- -.
Post #663116 30th Apr 2023 12:58pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
LED
Apart from price are these better, worst or the same?
https://www.amazon.co.uk/9005-OUSHI-HB3-He...mp;sr=8-15
It's that I'm not keen on eBay. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #663118 30th Apr 2023 1:50pm
they are different in looks ...the ones i bought are identical to an ebay sellers ones priced at £69.90 .. ... - .- -.
Post #663120 30th Apr 2023 2:03pm
Ryanmt
United Kingdom 2017 Range Rover Autobiography SDV6 Santorini Black
I have done the same and went with these ones, much brighter and a much whiter light (but not blue).
https://www.aliexpress.com/item/1005003688...1802hBwbAO
Post #663332 3rd May 2023 8:08am
they certainly make a difference dont they.. Thumbs Up
i've not been able to get the benefits with mine as its getting lighter in the evenings now Laughing ... - .- -.
Post #663336 3rd May 2023 8:57am
