Home > Technical (L322) > Tow bar
If you want to tow and add the carrier at the same time then the farmers hitch is the one for you. There is nothing that can't be fixed with a hammer😜😜
Post #201780 31st Jul 2013 7:02pm
northernmonkeyjones wrote:
Farmers hitch type or detachable (farmers can be removed as well but its a bit more of a faf)
Doesn't have to be..... Mine is less hassle than my old 'detachable' and looks a whole lot neater when removed - as shown in your photo.
What you need is a pin rather than a bolt - like this -
If you want to tow & carry bikes, then you can't carry many bikes or need a fairly light trailer otherwise you run the risk of overloading the nose weight on the hitch....
Post #201811 31st Jul 2013 9:08pm
good point on overloading the hitch, but with 150kg vertical load you should be pretty safe unless you are towing a big caravan with 100kg on the nose. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #201813 31st Jul 2013 9:16pm
johnboyairey
just noticed a 'fixed one on ebay going for a pound! 2007 on :item number eBay Item No. 251318057913
Post #204376 16th Aug 2013 3:24pm
