Home > Technical (L322) > Tow bar |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7945 |
Doesn't have to be..... Mine is less hassle than my old 'detachable' and looks a whole lot neater when removed - as shown in your photo. What you need is a pin rather than a bolt - like this - If you want to tow & carry bikes, then you can't carry many bikes or need a fairly light trailer otherwise you run the risk of overloading the nose weight on the hitch.... |
31st Jul 2013 9:08pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8620 |
good point on overloading the hitch, but with 150kg vertical load you should be pretty safe unless you are towing a big caravan with 100kg on the nose. There is nothing that can't be fixed with a hammer😜😜
31st Jul 2013 9:16pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
just noticed a 'fixed one on ebay going for a pound! 2007 on :item number eBay Item No. 251318057913 |
16th Aug 2013 3:24pm |
