![]() | Home > Technical (L322) > Tow bar |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7976 ![]() ![]() ![]() |
Doesn't have to be..... Mine is less hassle than my old 'detachable' and looks a whole lot neater when removed - as shown in your photo. What you need is a pin rather than a bolt - like this - ![]() If you want to tow & carry bikes, then you can't carry many bikes or need a fairly light trailer otherwise you run the risk of overloading the nose weight on the hitch.... |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8702 ![]() ![]() ![]() |
good point on overloading the hitch, but with 150kg vertical load you should be pretty safe unless you are towing a big caravan with 100kg on the nose. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
just noticed a 'fixed one on ebay going for a pound! 2007 on :item number eBay Item No. 251318057913 |
