Home > Maintenance & Mods (L322) > New brakes have arrived |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35264 |
dont forget the pics.... ... - .- -.
2nd Jul 2013 9:02pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8503 |
Brakes done,
3rd Jul 2013 9:31pm |
Ok Here goes.
3rd Jul 2013 10:24pm |
nice job Mark, put in our wiki.. ... - .- -.
4th Jul 2013 8:08am |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
I'm all set to do this tomorrow bought new Brembo discs and pads. Do you need new caliper retaining bolts as suggested in post above or can I just reuse old ones? Present :2008 TDV8 HSE
7th Oct 2013 12:27pm |
just clean the pins up and put them back.. ... - .- -.
7th Oct 2013 1:26pm |
Just did this today fitted Brembo discs and pads. Discs really did need replacing so glad I had the info as per Mark above really straight forward Present :2008 TDV8 HSE
15th Feb 2014 10:10pm |
There is nothing that can't be fixed with a hammer😜😜
15th Feb 2014 10:29pm |
Ok so now I have a 4.4 it time to swap the brakes on that too. I did the pads and disks when I bought it a few years back but the pads have started to squeal so thy are coming out anyway.
6th May 2018 1:36pm |
counter of beans Member Since: 18 Aug 2017 Location: Hampshire Posts: 182 |
I decided today to check that the pins weren't seized in the calipers. The top and bottom ones were fine; I cleaned them up and greased them with some Ceratec.
12th May 2018 1:31pm |
As you were doing.
12th May 2018 9:33pm |
Thanks NMJ, will give it another go tomorrow. |
14th May 2018 4:49pm |
OK, finally, job done. Great write up by NMJ, and I have nothing much to add. The middle pins are a rather odd design but just use a little brute force and they tap out (towards you on the outside of the car).
23rd May 2018 1:13pm |
i think i'll search for 'jurid' pads when i need new instead of LR branded ones.. ... - .- -.
23rd May 2018 2:38pm |
