![]() | Home > Maintenance & Mods (L322) > Black backside. |
'... I used that several years back for this same job, it has lasted extremely well and still looks as good as new - have never had to repeat the job. Wire brush, wipe down with meths (with box cold!) and allow few mins to dry, and then spray.'
NormanP Member Since: 15 Mar 2013 Location: Oxford Posts: 136 ![]() ![]() ![]() |
Yes, far as I can tell it looks like new / original style. Norman
I use SATIN Black spray. |
If the car is just put onto off road height, is it safe to get underneath and wire brush, clean and spray please??? |
Park your car overnight at offroad height and see if it does anything. Mine doesn't sag at all for days since my bags at the front have been replaced ![]() Have the Faultmate MSV2 Extreme to be tinkering with the settings etc. !! |
Thanks |
Done... One and a half aerosol cans of Hammerite High Heat Matt Black paint used. Looks very good.
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
I did mine at the weekend. All I did was to wire wool the 'box using dilute Autoglym All Purpose Cleaner, wipe clean and then sprayed with a satin black heat resistant fireplace paint.
You've missed a bit! |
20 months on and I've repainted the back box on ours. My originally applied Hammerite High Heat (Matt Black) spray was fine but for the odd small silver bare patch appearing through the black (not flaking paint almost as though it had rubbed off in areas).
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
If the suspension is up on high mode - make sure you leave a door open as the suspension will not drop if a door (or I think the tailgate) is open. |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
I have to say that if you plan to go under your FF without placing axle stands ( even for a 2 second job) you are mad. If that 'one in a million' event of a bag blowing happens when your under, the consequences could be serious.
YES its a door not tailgate needs to be open. ![]() |
