Home > Maintenance & Mods (L322) > Black backside.
Page 3 of 4 <1234>
NormanP
United Kingdom 2014 Range Rover Vogue TDV6 Aintree Green
pld118 wrote:
Changed it for Hammerite High Heat Matt Black Spray ...
I used that several years back for this same job, it has lasted extremely well and still looks as good as new - have never had to repeat the job. Wire brush, wipe down with meths (with box cold!) and allow few mins to dry, and then spray. Norman
Current LR: L405 Vogue TDV6 (MY 2014) Aintree Green/ Ivory interior
Past LR: L322 Vogue 4.4 V8 (2002); Discovery series1 V8 (1995)
Post #185028 27th Apr 2013 6:50am
pld118
'... I used that several years back for this same job, it has lasted extremely well and still looks as good as new - have never had to repeat the job. Wire brush, wipe down with meths (with box cold!) and allow few mins to dry, and then spray.'
Great thanks... I thought satin would likely look smart... Am presuming from what you say that the Hammerite matt black finish also looks smart if done well and is in keeping with the car??
Cheers
Post #185029 27th Apr 2013 6:57am
NormanP
Yes, far as I can tell it looks like new / original style. Norman
Post #185085 27th Apr 2013 11:38am
I use SATIN Black spray.
Post #185086 27th Apr 2013 12:00pm
pld118
If the car is just put onto off road height, is it safe to get underneath and wire brush, clean and spray please???
Post #186234 2nd May 2013 8:17pm
ebajema
Park your car overnight at offroad height and see if it does anything. Mine doesn't sag at all for days since my bags at the front have been replaced Smile I use it regularly in offroad height when I need to be underneath (currently the gearbox issues). MY 2010 5.0 SC Galway green and sand interior!!
Post #186264 2nd May 2013 10:58pm
pld118
Thanks
Post #186266 2nd May 2013 11:05pm
pld118
Done... One and a half aerosol cans of Hammerite High Heat Matt Black paint used. Looks very good.
Think (Gaz Elliot's) satin finish might look even better than matt black though..
Post #189541 21st May 2013 7:28am
I did mine at the weekend. All I did was to wire wool the 'box using dilute Autoglym All Purpose Cleaner, wipe clean and then sprayed with a satin black heat resistant fireplace paint.
I used the same procedure on my old '02 Vogue without any problems at all.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Si. <This is my name.
Post #189542 21st May 2013 7:42am
pld118
You've missed a bit! Rolling with laughter
Post #189548 21st May 2013 8:21am
Mr. Green
Still not happy with those pipes. Need more work. Si. <This is my name.
Post #189551 21st May 2013 8:27am
pld118
20 months on...
20 months on and I've repainted the back box on ours. My originally applied Hammerite High Heat (Matt Black) spray was fine but for the odd small silver bare patch appearing through the black (not flaking paint almost as though it had rubbed off in areas).
The Satin black might look a better finish though, hopefully.
So I washed down the back box with a diluted APC and a cotton cloth, dried it and then patch repaired the small shiny bare parts with the original Hammerite High Heat spray before applying a good coat of this Halfords Satin Black spray (almost a full tin used) @ £7.50/500 ml
As I've put one good coat over a good base layer of Hammerite Matt black I'm wondering if I'll need to do a second coat (although I bought 2 tins anyway):
The Westfalia rear tow eye and opposite near side bracket are a little surface corroded albeit out of sight so I've wire brushed them and prep'd them ready to hand paint them with this to avoid getting overspray everywhere:
Post #308527 27th Jan 2015 5:07pm
wealy
If the suspension is up on high mode - make sure you leave a door open as the suspension will not drop if a door (or I think the tailgate) is open.
Post #308539 27th Jan 2015 5:51pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
I have to say that if you plan to go under your FF without placing axle stands ( even for a 2 second job) you are mad. If that 'one in a million' event of a bag blowing happens when your under, the consequences could be serious.
Just my 2p worth Thumbs Up GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #308542 27th Jan 2015 6:16pm
YES its a door not tailgate needs to be open. Thumbs Up
Post #308543 27th Jan 2015 6:21pm
Page 3 of 4 <1234>
