![]() | Home > In Car Electronics (L322) > Satnav disc issues |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35663 ![]() ![]() |
i can only think that its thicker than the original disc because its a copy? ... - .- -.
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 968 ![]() ![]() ![]() |
Original wont go back in either...... |
do you mean it wont 'feed/suck' in.. ... - .- -.
It sucks/feeds but stops short before its all in? |
try inserting the original disc a few more times ,if this does not work i would try the battery disconnection jobby, failing this its unit out and strip down to see what the obstruction is.. ... - .- -.
Oh dear, have we got stuff on the wiki for this sort of thing? |
i dont think so...its strange that it wont go all the way in...a system reboot would be a first step.. ... - .- -.
Disc is jammed now, so will have to take sat nav out.....does the front pop off do u have to take the bolts at the side off....? |
i've never done it sorry..i'm sure someone will be on soon that has or knows how.. ... - .- -.
when cd's get stuck in the cd changer ,a tap on the unit with something like a screwdriver will make the cd come out...now i'm not saying that this method will work on the nav unit but its worth a try but be careful .. ... - .- -.
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 910 ![]() ![]() ![]() |
Take out the bolts (metric 8mm) two on either side, slide unit out and disconnect the connectors.
Cheers guys, will have a crack tomorrow and let you know how I get on..... |
ok so changer now out and the disc seems to be stuck on the "roof" of the changer inside any ideas i could get this out short of getting a pair of thin nose pliers in and pulling it out? |
if you did get the disc out with pliers with out breaking it ,which is very easily done, you still have to strip the unit down to see why the discs were getting stuck..
